Datasheet RH3845MK (Analog Devices) - 7
Description | Radiation Hardened High Voltage Synchronous Step-Down Controller |
Pages / Page | 8 / 7 — PACKAGE DESCRIPTION. W Package. 16-Lead Flatpak Glass Sealed (Hermetic) |
File Format / Size | PDF / 263 Kb |
RH3845MW
PACKAGE DESCRIPTION W Package 16-Lead Flatpak Glass Sealed (Hermetic)
(Reference LTC DWG # 05-08-7003 Rev Ø) 0.440* (11.176) 0.004 – 0.006** 0.017** MAX 0.005 (0.102 – 0.152) (0.431) (0.127) TYP MIN (4PLCS) 0.250 – 0.370 (6.350 – 9.398) DETAIL A 0.005 (0.127) 0.245 – 0.285* MAX (6.223 – 7.240) 0.005 DETAIL (0.127) A TYP 0.250 – 0.370 (6.350 – 9.398) 0.026 – 0.045 0.050 0.0425 – 0.0525*** (0.660 – 1.143) (1.270) (1.080 – 1.333) 0.045 – 0.085 BSC (4PLCS) (1.14 – 2.16) W16 (GLASS) 1119 REV Ø NOTES: *THIS DIMENSION DOES NOT ALLOW FOR OFF-CENTER LID, MENISCUS AND GLASS OVERRUN **INCREASE DIMENSIONS BY 0.003 INCHES (0.076mm) WHEN LEAD FINISH A IS APPLIED (SOLDER DIPPED) ***THIS DIMENSION NOT INCLUDE FOR A MAXIMUM 0.020 INCHES (0.508mm) OFF-SET TO CENTER LID Rev. 0 For more information www.analog.com 7 Document Outline Description Typical Application Absolute Maximum Ratings Package Information Table 1: Electrical characteristics Table 2: Electrical characteristics Electrical Characteristics: Burn-In Delta Parameters Electrical Test Requirements Total Dose Bias Circuit — Run Mode Total Dose Bias Circuit — Shutdown Mode Burn-In Circuit—Run Mode Package Description Typical Performance Characteristics
