Datasheet ADA4500-2 (Analog Devices)
Description10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier
Pages / Page24 / 1 — 10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O,. Zero Input Crossover Distortion …
RevisionB
10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O,. Zero Input Crossover Distortion Amplifier. Data Sheet. ADA4500-2. FEATURES
Datasheet ADA4500-2 Analog Devices, Revision: B
link to page 8 link to page 8
10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier Data Sheet ADA4500-2 FEATURES PIN CONFIGURATION Power supply rejection ratio (PSRR): 98 dB minimum OUT A 1 8 V+ Common-mode rejection ratio (CMRR): 95 dB minimum –IN A 2 7 OUT B ADA4500-2 Offset voltage: 120 μV maximum TOP VIEW +IN A 3 6 –IN B Single-supply operation: 2.7 V to 5.5 V (Not to Scale)
1 00 7-
Dual-supply operation: ±1.35 V to ±2.75 V V– 4 5 +IN B
61 10
Wide bandwidth: 10 MHz
Figure 1. 8-Lead MSOP Pin Configuration
Rail-to-rail input and output
For more information on the pin connections, see the Pin
Low noise
Configurations and Function Descriptions section
2 μV p-p from 0.1 Hz to 10 Hz 14.5 nV/√Hz at 1 kHz 100 ADA4500-2 Very low input bias current: 2 pA maximum 80 VSY = 5.0V APPLICATIONS 60 40 Pressure and position sensors Remote security 20 V) Medical monitors 0 OS Process controls V –20 Hazard detectors –40 Photodiode applications –60 –80 –100
4
0 1 2 3 4 5
-00 7
VCM (V)
61 10 Figure 2. The ADA4500-2 Eliminates Crossover Distortion Across its Full Supply Range
GENERAL DESCRIPTION
The ADA4500-2 is a dual 10 MHz, 14.5 nV/√Hz, low power This combination of features makes the ADA4500-2 an ideal choice amplifier featuring rail-to-rail input and output swings while for precision sensor applications because it minimizes errors due to operating from a 2.7 V to 5.5 V single power supply. Compatible power supply variation and maintains high CMRR over the full with industry-standard nominal voltages of +3.0 V, +3.3 V, input voltage range. The ADA4500-2 is also an excellent amplifier +5.0 V, and ±2.5 V. for driving analog-to-digital converters (ADCs) because the output Employing a novel zero-crossover distortion circuit topology, this does not distort with the common-mode voltage, which enables amplifier offers high linearity over the full, rail-to-rail input the ADC to use its full input voltage range, maximizing the common-mode range, with excellent power supply rejection ratio dynamic range of the conversion subsystem. (PSRR) and common-mode rejection ratio (CMRR) performance Many applications such as sensors, handheld instrumentation, without the crossover distortion seen with the traditional precision signal conditioning, and patient monitors can benefit complementary rail-to-rail input stage. The resulting op amp from the features of the ADA4500-2. also has excellent precision, wide bandwidth, and very low The ADA4500-2 is specified for the extended industrial temperature bias current. range (−40°C to +125°C) and available in the standard 8-lead MSOP and 8-lead LFCSP packages.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012-2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VSY = 2.7 V ELECTRICAL CHARACTERISTICS VSY = 5.0 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL OUTPUT RAIL-TO-RAIL INPUT (RRI) ZERO CROSS-OVER DISTORTION OVERLOAD RECOVERY POWER-ON CURRENT PROFILE APPLICATIONS INFORMATION RESISTANCE AND CAPACITANCE SENSOR CIRCUIT ADAPTIVE SINGLE-ENDED-TO-DIFFERENTIAL SIGNAL CONVERTER The Challenge The Solution OUTLINE DIMENSIONS ORDERING GUIDE
