Datasheet AD826 (Analog Devices) - 4
DescriptionHigh-Speed, Low-Power Dual Operational Amplifier
Pages / Page15 / 4 — AD826. – Typical Characteristics. 7.7. mA –. Volts. 7.2. +VCM. +85. +25. …
RevisionC
File Format / SizePDF / 738 Kb
AD826. – Typical Characteristics. 7.7. mA –. Volts. 7.2. +VCM. +85. +25. 6.7. –VCM. –40. 6.2. INPUT COMMON-MODE RANGE
AD826 – Typical Characteristics 7.7 mA – Volts 7.2 +VCM +85 +25 6.7 –VCM –40 6.2 INPUT COMMON-MODE RANGE
AD826 – Typical Characteristics 20 7.7 mA – Volts 15 7.2 +VCM +85 C +25 C 10 6.7 –VCM –40 C 5 6.2 INPUT COMMON-MODE RANGE QUIESCENT SUPPLY CURRENT PER AMP 0 5.7 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE – Volts SUPPLY VOLTAGE – Volts
Figure 1. Common-Mode Voltage Range vs. Supply Figure 4. Quiescent Supply Current per Amp vs. Supply Voltage for Various Temperatures
20 400 Volts 15 350 s RL = 500V V/ – 10 300 RL = 150V SLEW RATE 5 250 OUTPUT VOLTAGE SWING 0 200 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE – Volts SUPPLY VOLTAGE – Volts
Figure 2. Output Voltage Swing vs. Supply Figure 5. Slew Rate vs. Supply Voltage
30 100 25 V 10 Volts p-p S = 15V 20 15 1 10 V 0.1 S = 5V 5 OUTPUT VOLTAGE SWING CLOSED-LOOP OUTPUT IMPEDANCE 0 0.01 10 100 1k 10k 1k 10k 100k 1M 10M 100M LOAD RESISTANCE – FREQUENCY – Hz
Figure 3. Output Voltage Swing vs. Load Resistance Figure 6. Closed-Loop Output Impedance vs. Frequency –4– REV. C
