Datasheet AD711 (Analog Devices) - 4
DescriptionPrecision, Low Cost, High Speed, BiFET Op Amp
Pages / Page16 / 4 — AD711–Typical Performance Characteristics. lts. lts p-p. V 15. o V. …
RevisionE
File Format / SizePDF / 729 Kb
AD711–Typical Performance Characteristics. lts. lts p-p. V 15. o V. +VOUT. 15V SUPPLIES. GE SWING – 10. GE SWING –. RL = 2k. LTA. L = 2k. O 10
AD711–Typical Performance Characteristics lts lts p-p V 15 o V +VOUT 15V SUPPLIES GE SWING – 10 GE SWING – RL = 2k LTA L = 2k O 10
AD711–Typical Performance Characteristics 20 20 30 lts 25 lts o o V lts p-p V 15 15 o V +VOUT 20 15V SUPPLIES 10 GE SWING – 10 15 GE SWING – GE SWING – RL = 2k LTA LTA O O 25 C V R LTA L = 2k V O 10 25 C V 5 5 –VOUT INPUT 5 OUTPUT OUTPUT 0 0 0 0 5 10 15 20 0 5 10 15 20 10 100 1k 10k SUPPLY VOLTAGE – Volts SUPPLY VOLTAGE – Volts LOAD RESISTANCE –
TPC 1. Input Voltage Swing vs. TPC 2. Output Voltage Swing vs. TPC 3. Output Voltage Swing vs. Supply Voltage Supply Voltage Load Resistance
–6 2.75 10 100 AVCL = 1 –7 10 2.50 10 = 0) – Amps –8 10 CM ANCE – –9 2.25 10 1 –10 10 IESCENT CURRENT – mA 2.00 0.01 OUTPUT IMPED QU –11 10 INPUT BIAS CURRENT (V –12 1.75 10 0.01 0 5 10 15 20 –60 –40 –20 0 20 40 60 80 100 120 140 1k 10k 100k 1M 10M SUPPLY VOLTAGE – Volts TEMPERATURE – C FREQUENCY – Hz
TPC 4. Quiescent Current vs. Sup- TPC 5. Input Bias Current vs. Tem- TPC 6. Output Impedance vs. Fre- ply Voltage perature quency
100 26 5.0 VS = 15V 24 25 C +OUTPUT CURRENT 75 22 – MHz 4.5 T 20 50 18 4.0 –OUTPUT CURRENT MAX J GRADE LIMIT 16 25 CIRCUIT CURRENT LIMIT – mA 14 3.5 INPUT BIAS CURRENT – pA 12 UNITY GAIN BANDWIDTH SHORT 10 0 3.0 –10 –5 0 5 10 –60 –40 –20 0 20 40 60 80 100 120 140 –60 –40 –20 0 20 40 60 80 100 120 140 COMMON MODE VOLTAGE – Volts AMBIENT TEMPERATURE – C TEMPERATURE – C
TPC 7. Input Bias Current vs. Com- TPC 8. Short Circuit Current Limit TPC 9. Unity Gain Bandwidth vs. mon Mode Voltage vs. Temperature Temperature –4– REV. E Document Outline FEATURES PRODUCT DESCRIPTION CONNECTION DIAGRAMS PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics OPTIMIZING SETTLING TIME OP AMP SETTLING TIME—A MATHEMATICAL MODEL GUARDING D/A CONVERTER APPLICATIONS NOISE CHARACTERISTICS DRIVING THE ANALOG INPUT OF AN A/D CONVERTER DRIVING A LARGE CAPACITIVE LOAD ACTIVE FILTER APPLICATIONS SECOND ORDER LOW PASS FILTER 9-POLE CHEBYCHEV FILTER OUTLINE DIMENSIONS Revision History
