Datasheet AOZ1374DI (Alpha & Omega) - 3
ManufacturerAlpha & Omega
DescriptionECPower 23 V 36 mΩ Protection Switch Programmable Current Limit and True Reverse Current Blocking
Pages / Page18 / 3 — ALPHA & OMEGA. AOZ1374DI. Absolute Maximum Ratings. Recommended …
ALPHA & OMEGA. AOZ1374DI. Absolute Maximum Ratings. Recommended Operating Conditions. Parameter. Rating
ALPHA & OMEGA AOZ1374DI Absolute Maximum Ratings Recommended Operating Conditions Parameter Rating
ALPHA & OMEGA
S E M I C O N D U C T O R
Exceeding the Absolute Maximum ratings may damage the The device is not guaranteed to operate beyond the device. Maximum Recommended Operating Conditions.
Parameter Rating Parameter Rating
VIN, VOUT to GND -0.3 V to +28 V VIN, VOUT to GND 3.4 V to 23 V EN, ILIM, SS, FLTB, OVP to GND -0.3 V to +6 V EN, ILIM, SS, FLTB to GND 0 V to 5.5 V Junction Temperature (T OVP to GND 0 V to 3 V J) +150 °C Storage Temperature (T Switch DC Current (I S) -65 °C to +150 °C SW) 0 A to 3.5 A ESD Rating HBM All Pins ±4 kV Junction Temperature (TJ) -40 °C to +125 °C IEC 61000-4-2 at VOUT ±8 kV Package Thermal Resistance (ΘJA) 50 °C/W
Electrical Characteristics
TA = 25 °C, VIN = 12 V, EN = 5 V, unless otherwise specified.
Symbol Parameter Conditions Min Typ Max Unit General
V Input Supply Voltage 3.4 23 V IN V Under-Voltage Lockout Threshold VIN rising 2.9 3.35 V UVLO_R V Under-Voltage Lockout Hysteresis VIN falling 250 mV UVLO_HYS I Input Quiescent Current IN_ON IOUT = 0 A 0.9 mA I Input Shutdown Current EN = 0 V 5 µA IN_OFF VIN = 20 V, I R Switch On Resistance OUT = 1 A 36 mΩ ON VIN = 5 V, IOUT = 1 A 39 V Enable Input Logic High Threshold EN rising 1.05 1.15 1.32 V EN_H V Enable Input Logic Low Threshold EN falling 0.88 1.00 1.15 V EN_L I Enable Input Bias Current EN = 1.8 V 20 nA EN_BIAS V FLTB Pull-down Voltage FLTB_LO ISINK = 3 mA 0.3 V
Dynamic Characteristics
t Turn-On Delay Time (From EN 50% to VIN = 12 V, CSS = 22 nF 1.1 ms D_ON VOUT = 0.5 V) RLIM = 3.26 kΩ t Turn-On Time (VOUT from 10% to 90% of VIN = 12 V, CSS = 22 nF 2.6 ms ON 12V VIN) RLIM = 3.26 kΩ t FLTB Recovery Time Fault is removed REC (AOZ1374DI-01 Only) 150 ms
True Reverse-Current Blocking (TRCB)
V TRCB Protection Trip Point VOUT-VIN, VOUT rising 30 mV T_TRCB t TRCB Response Time TRCB VOUT-VIN > VT_TRCB + 500 mV 1 µs Rev. 1.0 December 2020
www.aosmd.com
Page 3 of 18
