Datasheet MSLSA (MSI) - 2
ManufacturerMSI
DescriptionLow Power Spectrum Analyzer
Pages / Page8 / 2 — Low Power Spectrum Analyzer. Data Sheet. Electrical Characteristics. MSLSA
File Format / SizePDF / 77 Kb
Low Power Spectrum Analyzer Data Sheet Electrical Characteristics MSLSA
(VDD = +5.0V, T = 25 C) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS ------------------------------------------------------------------------------------------------------------------------------------------------------------ DC Specifications ------------------------------------------------------------------------------------------------------------------------------------------------------------ Operating Voltage VDD 3.0 5.0 5.5 V ------------------------------------------------------------------------------------------------------------------------------------------------------------ Supply Current IDD PD=0V 2 mA ------------------------------------------------------------------------------------------------------------------------------------------------------------ Output Current IO RL = 100 KΩ 1.0 mA ------------------------------------------------------------------------------------------------------------------------------------------------------------ Supply Current IDD PD=0.5VDD 5 mA ------------------------------------------------------------------------------------------------------------------------------------------------------------ Output Current IO RL = 100 KΩ 1.0 mA ------------------------------------------------------------------------------------------------------------------------------------------------------------ Power Down Current IPD PD=VDD 400 μA ------------------------------------------------------------------------------------------------------------------------------------------------------------
MSLSA
AC Specifications ------------------------------------------------------------------------------------------------------------------------------------------------------------ Output Impedance Zo 500 Ω ------------------------------------------------------------------------------------------------------------------------------------------------------------ Clock to Corner Ratio fclk/fcnr Filter 1 89.08 Hz/Hz Clock to Corner Ratio fclk/fcnr Filter 2 79.36 Hz/Hz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Clock to Corner Ratio fclk/fcnr Filter 3 70.62 Hz/Hz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Clock to Corner Ratio fclk/fcnr Filter 4 63 Hz/Hz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Clock to Corner Ratio fclk/fcnr Filter 5 56.12 Hz/Hz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Clock to Corner Ratio fclk/fcnr Filter 6 50 Hz/Hz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Maximum Center Frequency fcenter Filter 6 Output 2 MHz ----------------------------------------------------------------------------------------------------------------------------------------------------------- Maximum Center Frequency fcenter Filter 6 PD=1/2 VDD 0.1 MHz ------------------------------------------------------------------------------------------------------------------------------------------------------------ Ripple 0.2 dB ----------------------------------------------------------------------------------------------------------------------------------------------------------- Input Offset Voltage VOS 3.3 mV ------------------------------------------------------------------------------------------------------------------------------------------------------------ 40 dB Bandwidth Normalized Fo 0.76 1.32 ------------------------------------------------------------------------------------------------------------------------------------------------------------ Filter Q Q 9 Unity Gain Bandwidth BW PD=1/2 VDD 6 MHz Web Site “www.mix-ssig.com” ©2007-2 2017 Mixed Signal Integration 2
