Datasheet ADHV4702-1 (Analog Devices) - 9
Description24 V to 220 V Precision Operational Amplifier
Pages / Page21 / 9 — Data Sheet. ADHV4702-1. MEAN: ±0.15mV. 135. 300. PHASE MARGIN. 250. ree. …
File Format / SizePDF / 626 Kb
Data Sheet. ADHV4702-1. MEAN: ±0.15mV. 135. 300. PHASE MARGIN. 250. ree. 200. (De. dB (. 150. ARG. 100. HAS. A = –40°C. –10. TA = 0°C. TA = +25°C. TA = +85°C
Data Sheet ADHV4702-1 MEAN: ±0.15mV 135 300 PHASE MARGIN 250 ree 200 (De dB ( 150 ARG 100 HAS A = –40°C –10 TA = 0°C TA = +25°C TA = +85°C
Data Sheet ADHV4702-1 MEAN: ±0.15mV 60 135 300 50 PHASE MARGIN 250 40 90 s) S ree IT g 200 30 UN ) (De F IN O dB ( R 20 45 150 OL ARG BE A M M 10 E A NU OL 100 HAS 0 0 P T 50 A = –40°C –10 TA = 0°C TA = +25°C TA = +85°C 0 –20 –45 –0.6 –0.4 –0.2 0 0.2 0.4 0.6 10k 100k 1M 10M 100M
-321 311 47
VOS (mV)
047-
FREQUENCY (Hz)
160 16 Figure 11. Input Offset Voltage Distribution, TA = 25°C, VS = ±110 V, Figure 14. AOL and Phase Margin vs. Frequency at Various TA, VS = ±110 V, VCM = 0 V, RADJ = 0 Ω RADJ = 0 Ω
180 180 180 AOL 160 160 PHASE 140 140 135 120 120 rees) g ) B 100 90 ) (d 100 B (De R (d 80 IN R 80 OL RG A CM A 60 45 M 60 E 40 AS H 40 P 20 0 20 0 0 –20 –45 0.01 0.1 1 10 100 1k 10k 100k 1M 10M
008 7-
0.001 0.01 0.1 1 10 100 1k 10k 100k 1M 10M 100M
009
FREQUENCY (Hz)
1604
FREQUENCY (Hz)
16047- Figure 12. CMRR vs. Frequency, TA = 25°C, VS = ±110 V, RLOAD = 10 kΩ, Figure 15. AOL and Phase Margin vs. Frequency, TA = 25°C, VS = ±110 V, RADJ = 0 Ω RADJ = 0 Ω
150 150 100 100 50 TA = –40°C 50 TA = 0°C T ) T A = –40°C V A = +25°C ) T ( T A = 0°C A = +85°C V T ( T 0 T 0 A = +25°C T OU A = +85°C V OUV –50 –50 –100 –100
010
–150
47-
–150
011
TIME (1µs/DIV)
160
TIME (1µs/DIV)
047- 16 Figure 13. Large Signal Pulse Response at Various TA, Rising Edge, AV = 20, Figure 16. Large Signal Pulse Response at Various TA, Falling Edge, AV = 20, VS = ±110 V, VOUT = 200 V p-p, RF = 100 kΩ, RLOAD = 10 kΩ, RADJ = 0 Ω VS = ±110 V, VOUT = 200 V p-p, RF = 100 kΩ, RLOAD = 10 kΩ, RADJ = 0 Ω Rev. B | Page 9 of 21 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ±12 V TO ±110 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INTERNAL ELECTROSTATIC DISCHARGE (ESD) PROTECTION SLEW BOOST CIRCUIT AND PROTECTION DIGITAL GROUND (DGND) RESISTOR ADJUSTABLE QUIESCENT CURRENT (RADJ) SHUTDOWN PIN (SDB) TEMPERATURE MONITOR (TMP) OVERTEMPERATURE PROTECTION OUTPUT CURRENT DRIVE AND SHORT-CIRCUIT PROTECTION EXTERNAL COMPENSATION AND CAPACITIVE LOAD (CLOAD) DRIVING SAFE OPERATING AREA LFCSP PACKAGE AND HIGH VOLTAGE PIN SPACING EXPOSED PAD (EPAD) APPLICATIONS INFORMATION POWER SUPPLY AND DECOUPLING HIGH VOLTAGE GUARD RING HIGH VOLTAGE DAC VOLTAGE SUBTRACTOR HIGH CURRENT OUTPUT DRIVER SIGNAL RANGE EXTENDER OUTLINE DIMENSIONS ORDERING GUIDE
