Datasheet OP177 (Analog Devices) - 5
DescriptionUltraprecision Operational Amplifier
Pages / Page16 / 5 — Data Sheet. OP177. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. …
RevisionH
File Format / SizePDF / 350 Kb
Data Sheet. OP177. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Ratings. Table 4. Thermal Resistance
Data Sheet OP177 ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Ratings Table 4 Thermal Resistance
Data Sheet OP177 ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Ratings
θJA is specified for worst-case mounting conditions, that is, θJA is Supply Voltage ±22 V specified for device in socket for PDIP; θJA is specified for Internal Power Dissipation1 500 mW device soldered to printed circuit board for SOIC package. Differential Input Voltage ±30 V Input Voltage ±22 V
Output Short-Circuit Duration Indefinite
Package Type θJA θJC Unit
Storage Temperature Range −65°C to +125°C 8-Lead PDIP (P-Suffix) 103 43 °C/W Operating Temperature Range −40°C to +85°C 8-Lead SOIC (S-Suffix) 158 43 °C/W Lead Temperature (Soldering, 60 sec) 300°C DICE Junction Temperature (T
ESD CAUTION
J) −65°C to +150°C 1 For supply voltages less than ±22 V, the absolute maximum input voltage is equal to the supply voltage. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. H | Page 5 of 16 Document Outline FEATURES PIN CONFIGURATION GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TEST CIRCUITS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GAIN LINEARITY THERMOCOUPLE AMPLIFIER WITH COLD-JUNCTION COMPENSATION PRECISION HIGH GAIN DIFFERENTIAL AMPLIFIER ISOLATING LARGE CAPACITIVE LOADS BILATERAL CURRENT SOURCE PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION POSITIVE PEAK DETECTOR PRECISION THRESHOLD DETECTOR/AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
