HMC5805ALS6 v02.0517 GaAs pHEMT MMIC 0.25 WATT POWER AMPLIFIERDC - 40 GHzTypical ApplicationsFeatures The HMC5805ALS6 is ideal for: High P1dB Output Power: 24.5 dBm T • Test Instrumentation M High Psat Output Power: 27 dBm • Microwave Radio & VSAT Gain: 11.5 dB • Military & Space Output IP3: 29 dBm R - S • Telecom Infrastructure Supply Voltage: +10 V @ 175 mA E • Fiber Optics 16 Lead Ceramic 6x6 mm SMT Package: 36 mm2 W O Functional DiagramGeneral Description R & P The HMC5805ALS6 is a GaAs pHEMT MMIC Dis- A tributed Power Amplifier which operates between DC E and 40 GHz. The amplifier provides 11.5 dB of gain, 29 dBm output IP3 and +24 dBm of output power at IN 1 dB gain compression while requiring 175 mA from a +10 V supply. The HMC5805ALS6 is ideal for EW, ECM, Radar and test equipment applications. The S - L HMC5805ALS6 amplifier I/Os are internal y matched R to 50 Ohms and the 6x6 mm SMT package is well IE suited for automated assembly techniques. LIF P M A Electrical Specifications, T = +25° C, Vdd = +10 V, Vgg2 = +3.5 V, Idd = 175 mA*A Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range DC - 5 5 - 30 30 - 40 GHz Gain 9 12.5 9 11.5 11.5 dB Gain Flatness ±1.0 ±0.75 ±0.75 dB Gain Variation Over Temperature 0.01 0.02 0.025 dB/ °C Input Return Loss 17 11 11 dB Output Return Loss 18 13 9 dB Output Power for 1 dB Compression (P1dB) 19 25 18 24.5 23 dBm Saturated Output Power (Psat) 27 27 26 dBm Output Third Order Intercept (IP3) 34 29 26 dBm Noise Figure 4.5 4 7 dB Supply Current 175 175 175 mA (Idd) (Vdd= 10V, Vgg1= -0.8V Typ.) * Adjust Vgg1 between -2 to 0 V to achieve Idd = 175 mA typical. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 1 rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Typical Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature Psat vs. Supply Voltage P1dB vs. Supply Current Psat vs. Supply Current Output IP3 vs. Temperature @ Pout = 14 dBm / Tone Output IP3 vs. Supply Voltage @ Pout = 14 dBm / Tone Output IP3 vs. Supply Currents @ Pout = 14 dBm / Tone Output IM3 @ Vdd = +10V Output IM3 @ Vdd = +11V Reverse Isolation vs. Temperature Power Compression @ 20 GHz Absolute Maximum Ratings Outline Drawing Pad Descriptions Application Circuit
