Datasheet HMC635 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 18 -40 GHz
Pages / Page8 / 3 — HMC635. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Power Compression …
File Format / SizePDF / 410 Kb
HMC635. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Power Compression @ 30 GHz. Power Compression @ 40 GHz
HMC635 GaAs PHEMT MMIC DRIVER AMPLIFIER, 18 - 40 GHz Power Compression @ 30 GHz Power Compression @ 40 GHz
HMC635
v00.1107
2 30 30 Pout (dBm) Pout (dBm) 25 Gain (dB) 25 Gain (dB) PAE (%) PAE (%) 20 20 IP H 15 15 10 10 - C S 5 5 Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) R 0 0 IE -15 -10 -5 0 5 10 -15 -10 -5 0 5 10 INPUT POWER (dBm) INPUT POWER (dBm) IF L P M
Output IP3 vs. Temperature Noise Figure vs. Temperature
40 15 K A 36 12 OC 32 9 28 GURE (dB) BL IP3 (dBm) 6 SE FI IN 24 NOI +25 C A +25 C 3 +85 C 20 +85 C -55 C -55 C 16 0 & G 16 18 20 22 24 26 28 30 32 34 36 38 40 42 16 18 20 22 24 26 28 30 32 34 36 38 40 42 FREQUENCY (GHz) FREQUENCY (GHz) R E IV R
Gain & Power vs. Supply Voltage @ 30 GHz Reverse Isolation vs. Temperature
D 26 0 -10 24 +25 C -20 +85 C -55 C Gain 22 P1dB Bm), Psat (dBm) -30 Psat -40 20 ISOLATION (dB) -50 18 -60 GAIN (dB), P1dB (d 16 -70 4.5 4.6 4.7 4.8 4.9 5 5.1 5.2 5.3 5.4 5.5 16 18 20 22 24 26 28 30 32 34 36 38 40 42 Vdd (V) FREQUENCY (GHz) Information furnis F he o d r pri by An ce, de alog Devic leiv s ies ry be , a lievend to pla d to be accurce o ate an rd der relia s bl , pl e. Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 60
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n25 lin 0- e a 3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hit A tpite.co plicatio m n Support: Phone: 1-800-ANALOG-D
