Datasheet HMC633LC4 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 -17 GHz
Pages / Page8 / 5 — HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Outline …
File Format / SizePDF / 430 Kb
HMC633LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5.5 - 17 GHz. Outline Drawing. Package Information
HMC633LC4 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5.5 - 17 GHz Outline Drawing Package Information
HMC633LC4
v03.0514
T M S - S R IE LIF P M K A C LO IN B A NOTES: R & G 1. PACKAGE BODY MATERIAL: ALUMINA E 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER 50 MICROINCHES MINIMUM NICKEL. IV 3. DIMENSIONS ARE IN INCHES [MILLIMETERS]. R 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM -C- D 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC633LC4 Alumina, White Gold over Nickel MSL3 [1] H633 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
