Datasheet ADL5320 (Analog Devices) - 4
Description400 MHz TO 2700 MHz ¼ Watt RF Driver Amplifier
Pages / Page20 / 4 — ADL5320. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. S11. S21. …
File Format / SizePDF / 919 Kb
ADL5320. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. S11. S21. S12. S22. Freq (MHz)
ADL5320 Data Sheet TYPICAL SCATTERING PARAMETERS Table 2 S11 S21 S12 S22 Freq (MHz)
VSUP = 5 V and TA = 25°C; the effects of the test fixture have been de-embedded up to the pins of the device.
Table 2. S11 S21 S12 S22 Freq (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
400 −1.42 −179.88 +14.16 +134.74 −32.56 +13.47 −3.42 +176.22 500 −1.38 +175.04 +13.97 +126.21 −32.02 +8.58 −3.71 +175.38 550 −1.42 +173.05 +13.81 +122.24 −31.84 +6.81 −3.84 +175.10 600 −1.48 +171.25 +13.66 +118.41 −31.70 +5.25 −3.96 +174.89 650 −1.54 +169.59 +13.49 +114.71 −31.56 +3.85 −4.08 +174.74 700 −1.62 +168.11 +13.32 +111.12 −31.43 +2.63 −4.19 +174.71 750 −1.70 +166.66 +13.17 +107.64 −31.29 +1.35 −4.30 +174.74 800 −1.80 +165.36 +13.05 +104.27 −31.16 +0.20 −4.41 +174.89 850 −1.90 +163.99 +12.94 +100.86 −31.01 −0.95 −4.52 +175.10 900 −2.01 +162.65 +12.84 +97.48 −30.85 −2.23 −4.62 +175.37 950 −2.13 +161.32 +12.73 +94.09 −30.69 −3.43 −4.71 +175.78 1000 −2.27 +159.98 +12.65 +90.72 −30.52 −4.80 −4.81 +176.29 1050 −2.43 +158.61 +12.62 +87.34 −30.32 −6.24 −4.89 +176.85 1100 −2.63 +157.11 +12.59 +83.90 −30.15 −7.92 −4.98 +177.52 1150 −2.84 +155.60 +12.56 +80.41 −29.95 −9.61 −5.06 +178.29 1200 −3.09 +153.91 +12.55 +76.75 −29.74 −11.56 −5.12 +179.17 1250 −3.39 +152.08 +12.56 +73.03 −29.54 −13.63 −5.18 −179.85 1300 −3.73 +150.14 +12.57 +69.24 −29.33 −15.87 −5.25 −178.72 1350 −4.13 +147.98 +12.61 +65.23 −29.12 −18.39 −5.28 −177.52 1400 −4.59 +145.57 +12.66 +61.05 −28.91 −21.17 −5.29 −176.26 1450 −5.13 +143.05 +12.72 +56.75 −28.69 −24.17 −5.27 −174.93 1500 −5.76 +140.31 +12.79 +52.20 −28.48 −27.48 −5.19 −173.52 1550 −6.48 +137.18 +12.83 +47.46 −28.28 −31.05 −5.12 −172.60 1600 −7.36 +133.46 +12.89 +42.49 −28.10 −34.99 −5.06 −171.45 1650 −8.45 +129.65 +12.93 +37.41 −27.95 −39.05 −4.94 −170.38 1700 −9.74 +125.36 +12.98 +32.12 −27.81 -43.45 −4.80 −169.52 1750 −11.32 +120.71 +12.99 +26.74 −27.70 −48.12 −4.65 −168.95 1800 −13.34 +115.47 +12.99 +21.16 −27.61 −53.06 −4.47 −168.68 1850 −16.00 +109.24 +12.97 +15.43 −27.56 −58.23 -4.30 −168.76 1900 −19.89 +100.84 +12.93 +9.57 −27.55 −63.67 −4.14 −169.26 1950 −26.68 +83.39 +12.86 +3.65 −27.58 −69.38 −3.99 −170.11 2000 −33.34 −26.40 +12.76 −2.46 −27.65 −75.33 −3.86 −171.37 2050 −23.21 −71.32 +12.64 −8.60 −27.75 −81.44 −3.74 −172.97 2100 −18.39 −83.50 +12.49 −14.83 −27.89 −87.92 −3.65 −175.01 2150 −15.39 −92.08 +12.31 −21.09 −28.07 −94.55 −3.58 −177.37 2200 −13.26 −100.04 +12.11 −27.46 −28.29 −101.56 −3.54 +179.90 2250 −11.63 −107.86 +11.88 −33.90 −28.54 −108.80 −3.50 +176.83 2300 −10.31 −115.84 +11.62 −40.49 −28.82 −116.46 −3.47 +173.43 2350 −9.20 −123.94 +11.33 −47.09 −29.15 −124.41 −3.44 +169.75 2400 −8.23 −132.24 +11.01 −53.81 −29.50 −132.81 −3.42 +165.83 2450 −7.38 −140.88 +10.64 −60.65 −29.89 −141.70 −3.40 +161.63 2500 −6.61 −149.66 +10.24 −67.57 −30.31 −150.89 −3.36 +157.29 2550 −5.89 −158.59 +9.78 −74.53 −30.76 −160.57 −3.31 +152.82 2600 −5.23 −167.51 +9.27 −81.60 −31.23 −170.68 −3.24 +148.32 2650 −4.62 −176.26 +8.70 −88.50 −31.73 +178.90 −3.17 +143.81 2700 −4.05 +175.18 +8.07 −95.43 −32.22 +168.34 −3.09 +139.40 Rev. B | Page 4 of 20 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature and 3.3 V Operation Applications Information Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure Optimizing OP1dB W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
