Datasheet HMC-AUH318 (Analog Devices) - 4
DescriptionGaAs HEMT MMIC MEDIUM POWER AMPLIFIER, 71 -76 GHz
Pages / Page6 / 4 — HMC-AUH318. GaAs HEMT MMIC MEDIUM POWER. AMPLIFIER, 71 - 76 GHz. Pad …
File Format / SizePDF / 298 Kb
HMC-AUH318. GaAs HEMT MMIC MEDIUM POWER. AMPLIFIER, 71 - 76 GHz. Pad Descriptions. Application Circuit. 3 - 4
HMC-AUH318 GaAs HEMT MMIC MEDIUM POWER AMPLIFIER, 71 - 76 GHz Pad Descriptions Application Circuit 3 - 4
HMC-AUH318
v07.0713
Pad Number Function Description Interface Schematic This pad is AC coupled 1 RFIN and matched to 50 Ohms. Gate control for amplifier. Please follow “MMIC Amplifier 3 2, 3 Vgg1, Vgg2 Biasing Procedure” application note. See assembly for required external components. This pad is AC coupled 4 RFOUT IP and matched to 50 Ohms. H Power Supply Voltage for the amplifier. See assembly for 5, 6 Vdd1, Vdd2 required external components. R - C E Die Bottom GND Die bottom must be connected to RF/DC ground. W O
Application Circuit
R & P A E IN S - L R IE LIF P M A Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
3 - 4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
