Datasheet HMC609LC4 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz
Pages / Page8 / 4 — HMC609LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Output IP3 …
File Format / SizePDF / 470 Kb
HMC609LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 2 - 4 GHz. Output IP3 vs. Temperature [1]. Output IP3 vs. Temperature [2]
HMC609LC4 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Output IP3 vs Temperature [1] Output IP3 vs Temperature [2]
HMC609LC4
v03.0514
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 4 GHz Output IP3 vs. Temperature [1] Output IP3 vs. Temperature [2]
40 40 39 38 38 T 37 M ) 36 36 (dBm (dBm) 35 - S IP3 34 OIP3 34 +25C E +85C 33 -40C +25C IS 32 +85C 32 -40C O 31 30 30 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 FREQUENCY (GHz) FREQUENCY (GHz) W N O
Noise Figure vs. Temperature [2] Noise Figure vs. Temperature [1]
S - L 10 10 R 9 +25C IE 8 +85C 8 ) -40C ) +25C 7 +85C (dB (dB E -40C E LIF 6 R 6 R U U P IG IG 5 F F E 4 E 4 M IS IS O O N 3 N A 2 2 1 0 0 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 FREQUENCY (GHz) FREQUENCY (GHz)
Reverse Isolation vs. Temperature [1] Reverse Isolation vs. Temperature [2]
0 0 -10 -10 ) +25C ) -20 +85C -20 (dB -40C +25C (dB N N +85C IO -30 IO -40C T -30 T LA LA O O IS -40 IS -40 -50 -50 -60 -60 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 FREQUENCY (GHz) FREQUENCY (GHz) [1] Vdd = 6V [2] Vdd = 5V I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
