Datasheet HMC383 (Analog Devices)
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz
Pages / Page6 / 1 — HMC383. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Typical …
File Format / SizePDF / 355 Kb
HMC383. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC383 Analog Devices
HMC383
v02.0907
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz Typical Applications Features
The HMC383 is ideal for use as a driver amplifi er for: Gain: 16 dB • Point-to-Point Radios Saturated Output Power: +18 dBm 3 • Point-to-Multi-Point Radios & VSAT Output IP3: +25 dBm • Test Equipment & Sensors Single Positive Supply: +5V @ 101 mA • LO Driver for HMC Mixers 50 Ohm Matched Input/Output IP • Military & Space Die Size: 2.26 x 1.35 x 0.1 mm H
S - C R The HMC383 is a general purpose GaAs PHEMT MMIC Driver Amplifi er which operates between 12 IE and 30 GHz. The amplifi er provides 16 dB of gain IF L and +18 dBm of saturated power from a +5V supply. P Consistent gain and output power across the operating band make it possible to use a common M driver/LO amplifi er approach in multiple radio bands. The HMC383 amplifi er can easily be integrated into R A Multi-Chip-Modules (MCMs) due to its compact size, E single supply operation, and DC blocked RF I/Os. All W data is measured with the chip in a 50 Ohm test fi x- O ture connected via 0.025mm (1 mil) diameter wire bonds of minimal length 0.31mm (12 mils). R & P A E IN
Electrical Specifi cations, T = +25° C, Vdd = +5V
L
A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 12 - 18 18 - 24 24 - 28 28 - 30 GHz Gain 13 16 14 17 13 16 12 15 dB Gain Variation Over Temperature 0.03 0.04 0.03 0.04 0.03 0.04 0.03 0.04 dB/ °C Input Return Loss 14 12 14 7 dB Output Return Loss 13 12 7 5 dB Output Power for 1 dB Compression 12 15 13.5 16.5 13 16 13 16 dBm (P1dB) Saturated Output Power (Psat) 18 18 17 18 dBm Output Third Order Intercept (IP3) 25 25 24 23 dBm Noise Figure 9 7 6.5 7.5 dB Supply Current (Idd) 101 125 101 125 101 125 101 125 mA Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
3 - 2
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
