Datasheet ADCA3992 (Analog Devices)
Description | 45 MHz to 1218 MHz, CATV Power Doubler Hybrid |
Pages / Page | 9 / 1 — 45 MHz to 1218 MHz,. CATV Power Doubler Hybrid. Data Sheet. ADCA3992. … |
File Format / Size | PDF / 272 Kb |
45 MHz to 1218 MHz,. CATV Power Doubler Hybrid. Data Sheet. ADCA3992. FEATURES. FUNCTIONAL BLOCK DIAGRAM
45 MHz to 1218 MHz, CATV Power Doubler Hybrid Data Sheet ADCA3992 FEATURES FUNCTIONAL BLOCK DIAGRAM High RF output: 76.8 dBmV total composite power ADCA3992 DPD optimized High gain of 26.7 dB at 1218 MHz INPUT 1 Very low distortion Low noise figure: 3 dB at 45 MHz, 4.5 dB at 1218 MHz Unconditionally stable 9 OUTPUT Transient and surge protection V BIAS CC range from 24 V to 34 V 2 3 4 5 7 8 Configurable dc current from 300 mA to 550 mA maximum IADJ VCC
001
Industry-standard, 8-pin SOT115J module package GND GND
16777-
Figure 1.
45 MHz to 1218 MHz cable television (CATV) infrastructure amplifier systems Remote physical layer (PHY) and fiber deep nodes DOCSIS® 3.1 compliant GENERAL DESCRIPTION
The ADCA3992 is a high gain, power doubler hybrid amplifier high electron mobility transistor (pHEMT) die in combination optimized for a wide range of bias conditions for power with a gallium nitride (GaN) HEMT die. The dc current and efficiency and customer flexibility. The ADCA3992 is ideal y supply voltage can be adjusted external y for optimum distortion suited for use in digital predistortion (DPD) node designs for performance vs. power consumption over a range of output maximum power savings. The device achieves extremely high levels. The ADCA3992 is packaged in the industry-standard RF output, up to 76.8 dBmV composite power, or 67 dBmV SOT115J package. virtual level, using a gallium arsenide (GaAs) pseudomorphic
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2020 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS GENERAL PERFORMANCE DISTORTION DATA, 40 MHz TO 550 MHz ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
