Datasheet ADL5545 (Analog Devices) - 4
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page18 / 4 — ADL5545. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 373 Kb
ADL5545. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADL5545 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY = 2140 MHz Gain 21.1 21.8 22.4 dB vs. Frequency ±50 MHz ±0.09 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 16.2 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 35.7 dBm Noise Figure 3.5 dB FREQUENCY = 2600 MHz Gain 20.1 20.9 21.7 dB vs. Frequency ±50 MHz ±0.09 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.16 dB Output 1 dB Compression Point 15.7 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 34.6 dBm Noise Figure 3.6 dB FREQUENCY = 3500 MHz Gain 19.0 19.7 20.4 dB vs. Frequency ±50 MHz ±0.10 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.8 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 14.5 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 33.7 dBm Noise Figure 4.0 dB FREQUENCY = 4000 MHz Gain 17.8 18.6 19.4 dB vs. Frequency ±50 MHz ±0.14 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.0 dB vs. Supply 4.75 V to 5.25 V ±0.19 dB Output 1 dB Compression Point 13.1 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 29.0 dBm Noise Figure 4.6 dB FREQUENCY = 5000 MHz Gain 16.8 dB vs. Frequency ±50 MHz ±0.05 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.2 dB vs. Supply 4.75 V to 5.25 V ±0.20 dB Output 1 dB Compression Point 9.9 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 31.8 dBm Noise Figure 4.8 dB FREQUENCY = 5800 MHz Gain 15.9 dB vs. Frequency ±50 MHz ±0.20 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.3 dB vs. Supply 4.75 V to 5.25 V ±0.20 dB Output 1 dB Compression Point 9.4 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 28.4 dBm Noise Figure 5.2 dB POWER INTERFACE VPOS Supply Voltage 4.75 5 5.25 V Supply Current 56 70 mA vs. Temperature −40°C ≤ TA ≤ +85°C −6 mA Power Dissipation VPOS = 5 V 280 mW Rev. B | Page 4 of 18 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 100 MHz TO 500 MHz FREQUENCY BAND 4 GHz TO 6 GHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN OPERATION DOWN TO 30 MHz W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES
