Datasheet HMC754S8GE (Analog Devices) - 9
DescriptionGaAs HBT High Linearity Push-Pull Amplifier, 75 Ohm, DC - 1 GHz
Pages / Page10 / 9 — HMC754S8GE. GaAs HBT HIGH LINEARITY. PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 …
HMC754S8GE. GaAs HBT HIGH LINEARITY. PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 GHz
HMC754S8GE GaAs HBT HIGH LINEARITY PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 GHz
HMC754S8GE
v01.1119
GaAs HBT HIGH LINEARITY PUSH-PULL AMPLIFIER, 75 Ohm, DC - 1 GHz Evaluation PCB - Standard and Option 2 Application
8 T M K - S C LO IN B A R & G E IV R S - D
List of Materials for Evaluation PCB [1]
R The circuit board used in the final application Item Description IE should use RF circuit design techniques. Signal J1, J2 F-Connector lines should have 75 ohm impedance while the J3 - J6 DC PIN LIF package ground leads and package bottom should P C1 - C6 1 nF Capacitor, 0402 Pkg. be connected directly to the ground plane similar to C7, C8 4.7 µF Capacitor, Tantalum, 0603 Pkg. M that shown. A sufficient number of via holes should C9, C11 68 pF Capacitor, 0402 Pkg. A be used to connect the top and bottom ground C10, C12 10 nF Capacitor, 0402 Pkg. planes. The evaluation board should be mounted L1, L2 [2] Inductor, 0603 Pkg. to an appropriate heat sink. The evaluation circuit R1, R2 0 Ohm Resistor, 0603 Pkg. board shown is available from Analog Devices T1, T2 [2] 1:1 Transformer upon request. U1 HMC754S8GE Amplifier PCB [3] 124061 Evaluation PCB [1] When requesting an evaluation board, please reference the appropriate evaluation PCB number listed in the table “Components for Selected Options.” [2] Please refer to “Components for Selected Options” table for values [3] Circuit Board Material: Rogers 4350 or Arlon 25FR For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
8 - 9
Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Typical Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Output IP3 vs. Temperature Output IP2 vs. Temperature Noise Figure vs. Temperature P1dB vs. Temperature Reverse Isolation vs. Temperature Output IP2 vs. Output Power CSO / CTB / XMOD @ +15 dBmV input, 133 channels (Analog) Option 1 - Improved Input Return Loss & Gain Flatness (with Lower IP2) Application Gain & Return Loss Output IP2 vs. Frequency Output IP3 vs. Frequency Noise Figure vs. Frequency P1dB vs. Frequency Option 2 - 10 to 100 MHz Application Gain & Return Loss Output IP3 vs. Frequency Noise Figure vs. Frequency P1dB vs. Frequency Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Application Circuit for Push-Pull Operation Components for Selected Options Evaluation PCB Option 2 Application List of Materials Option 1 Application List of Materials
