Datasheet ADH519S (Analog Devices) - 5
Description17.5 GHz – 31.5 GHz Low Noise Amplifier
Pages / Page8 / 5 — ADH519S. TABLE IIA – ELECTRICAL TEST REQUIREMENTS:. Subgroups (in …
File Format / SizePDF / 186 Kb
ADH519S. TABLE IIA – ELECTRICAL TEST REQUIREMENTS:. Subgroups (in accordance with. Test Requirements. MIL-PRF-38535, Table III)
ADH519S TABLE IIA – ELECTRICAL TEST REQUIREMENTS: Subgroups (in accordance with Test Requirements MIL-PRF-38535, Table III)
Interim Electrical Parameters 1, 4 Final Electrical Parameters 1, 4 1/ 2/ Group A Test Requirements 1, 2, 3, 4, 5, 6 Group C end-point electrical parameters 1, 4 2/ Group D end-point electrical parameters 1, 4 Group E end-point electrical parameters 1, 4 3/ Table IIA Notes: 1/ PDA applies to Table I subgroup 1 and Table IIB delta parameters. 2/ See Table IIB for delta parameters 3/ Parameters noted in Table I are not tested post irradiation.
TABLE IIB – BURN-IN / LIFE TEST DELTA LIMITS 1/ 2/ 3/ Parameter Symbol Delta Units
Gain 18 GHz S21 ±1.0 dB Gain 28 GHz S21 ±1.5 dB Gain 31 GHz S21 ±1.5 dB Supply Current IDD ±10 % Table IIB Notes: 1/ 240 hour burn in and 1000 hour life test (group C) end point electrical parameters. 2/ Deltas are performed at room temperature TA = +25°C only. 3/ Deltas apply with VDD1 = VDD2 = VDD3 = 3.0V unless otherwise noted ASD0016589 Rev.A | Page 5 of 8
