Datasheet HMC1126 (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, Power Amplifier, 2 GHz to 50 GHz
Pages / Page16 / 3 — Data Sheet. HMC1126. ELECTRICAL SPECIFICATIONS 2 GHz TO 10 GHz FREQUENCY …
RevisionC
File Format / SizePDF / 333 Kb
Data Sheet. HMC1126. ELECTRICAL SPECIFICATIONS 2 GHz TO 10 GHz FREQUENCY RANGE. Table 1. Parameter. Symbol
Data Sheet HMC1126 ELECTRICAL SPECIFICATIONS 2 GHz TO 10 GHz FREQUENCY RANGE Table 1 Parameter Symbol
TA = 25°C, VDD = 5 V, VGG2 = 1.4 V, IDD = 65 mA, unless otherwise stated. Adjust VGG1 between −2 V to 0 V to achieve IDD = 65 mA typical.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 2 10 GHz GAIN 8 11 dB Gain Variation Over Temperature 0.002 dB/°C RETURN LOSS Input 12 dB Output 14 dB OUTPUT Output Power for 1 dB Compression P1dB 14.5 17.5 dBm Saturated Output Power PSAT 21 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 31 dBm NOISE FIGURE 4.5 TOTAL SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 65 mA
10 GHz TO 26 GHz FREQUENCY RANGE
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 10 26 GHz GAIN 8 10.5 dB Gain Variation Over Temperature 0.005 dB/°C RETURN LOSS Input 14 dB Output 20 dB OUTPUT Output Power for 1 dB Compression P1dB 14.5 17.5 dBm Saturated Output Power PSAT 21 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 28 dBm NOISE FIGURE 4 TOTAL SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 65 mA Rev. C | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY ELECTRICAL SPECIFICATIONS 2 GHz TO 10 GHz FREQUENCY RANGE 10 GHz TO 26 GHz FREQUENCY RANGE 26 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 50 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
