Datasheet HMC618ALP3E (Analog Devices) - 3
DescriptionGaAs SMT pHEMT Low Noise Amplifier, 1.2 - 2.2 GHz
Pages / Page14 / 3 — HMC618ALP3E. GaAs SMT pHEMT LOW NOISE. AMPLIFIER, 1.2 - 2.2 GHz. 1700 to …
File Format / SizePDF / 961 Kb
HMC618ALP3E. GaAs SMT pHEMT LOW NOISE. AMPLIFIER, 1.2 - 2.2 GHz. 1700 to 2200 MHz Tune. Output Return Loss vs. Temperature [1]
HMC618ALP3E GaAs SMT pHEMT LOW NOISE AMPLIFIER, 1.2 - 2.2 GHz 1700 to 2200 MHz Tune Output Return Loss vs Temperature [1]
HMC618ALP3E
v01.0519
GaAs SMT pHEMT LOW NOISE AMPLIFIER, 1.2 - 2.2 GHz 1700 to 2200 MHz Tune Output Return Loss vs. Temperature [1] Reverse Isolation vs. Temperature [1]
0 0 T -5 -5 M ) -10 B ) (d B d S -10 ( -15 S N O L IO T -20 N A L -15 E - S UR O T -25 IS RE -30 IS -20 -35 O -25 -40 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 FREQUENCY (GHz) FREQUENCY (GHz) W N +25 C +85 C - 40 C +25 C +85 C - 40 C O S - L
Noise Figure vs Temperature [1] [2] [3] Output P1dB vs. Temperature [1] [2]
R 1.6 24 IE 1.4 22 Vdd=5V ) 1.2 B +85C 20 d ( LIF ) E 1 +25 C m R 18 U P IG 0.8 (dB F 16 E M 1dB Vdd=3V IS 0.6 P O -40C A N 14 0.4 12 0.2 0 10 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 1.6 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) Vdd=5V Vdd=3V +25 C +85 C - 40 C
Psat vs. Temperature [1] [2] Output IP3 vs. Temperature [1] [2]
24 40 Vdd=5V 22 38 Vdd=5V 36 20 ) m Vdd=3V 34 B 18 m d (dB 32 t ( a 3 16 s IP P 30 14 28 12 26 Vdd=3V 10 24 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 1.6 1.7 1.8 1.9 2 2.1 2.2 2.3 FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C +25 C +85 C - 40 C [1] Vdd = 5V, Rbias = 470 Ohm [2] Vdd = 3V, Rbias = 10K Ohm [3] Measurement reference plane shown on evaluation PCB drawing. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications 1200 to 1700 MHz Tune Gain vs. Temperature Gain vs. Temperature Input Return Loss vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Output Return Loss vs. Temperature Reverse Isolation vs. Temperature Reverse Isolation vs. Temperature Noise Figure vs. Temperature Noise Figure vs. Temperature Output P1dB vs. Temperature Output P1dB vs. Temperature Psat vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Output IP3 vs. Temperature 1700 to 2200 MHz Tune Broadband Gain & Return Loss Gain vs. Temperature Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Reverse Isolation vs. Temperature Noise Figure vs Temperature Output P1dB vs. Temperature Psat vs. Temperature Output IP3 vs. Temperature Output IP3 and Idd vs. Supply Voltage @ 1750 MHz Output IP3 and Idd vs. Supply Voltage @ 1750 MHz Output IP3 and Idd vs. Supply Voltage @ 2100 MHz Output IP3 and Idd vs. Supply Voltage @ 2100 MHz Power Compression @ 1750 MHz Power Compression @ 1750 MHz Power Compression @ 2100 MHz Power Compression @ 2100 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 1750 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 1750 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 2100 MHz Gain, Power & Noise Figure vs. Supply Voltage @ 2100 MHz Output IP3 vs. Rbias @ 1750 MHz Gain, Noise Figure vs. Rbias @ 1750 MHz Output IP3 vs. Rbias @ 2100 MHz Gain, Noise Figure vs. Rbias @ 2100 MHz Absolute Bias Resistor Range & Recommended Bias Resistor Values for Idd Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Package Information Pin Descriptions Evaluation PCB 1700 to 2200 MHz Tune Application Circuit Evaluation PCB Ordering Information List of Materials 1200 to 1700 MHz Tune Application Circuit Evaluation PCB Ordering Information List of Materials
