Datasheet HMC-AUH312 (Analog Devices) - 5
Description0.5 GHz to 80 GHz, GaAs, HEMT, MMIC, Low Noise Wideband Amplifier
Pages / Page17 / 5 — Data Sheet. HMC-AUH312. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. …
RevisionF
File Format / SizePDF / 473 Kb
Data Sheet. HMC-AUH312. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. ESD CAUTION
Data Sheet HMC-AUH312 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
Data Sheet HMC-AUH312 ABSOLUTE MAXIMUM RATINGS Table 5. Parameter Rating
Stresses at or above those listed under Absolute Maximum Drain Bias Voltage with Bias Tee (VDD) 7 V dc Ratings may cause permanent damage to the product. This is a Drain Bias Voltage Without Bias Tee (VDD) 8.25 V dc stress rating only; functional operation of the product at these Gain Bias Voltage (VGG1) 0.5 V or any other conditions above those indicated in the operational Gain Bias Voltage (VGG2) 2 V section of this specification is not implied. Operation beyond RF Input Power 10 dBm the maximum operating conditions for extended periods may Channel Temperature 180°C affect product reliability. Storage Temperature Range −40°C to +85°C
ESD CAUTION
Operating Temperature Range −55°C to +85°C Rev. F | Page 5 of 6 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 0.5 GHz to 60 GHz Frequency Range 60 GHz to 80 GHz Frequency Range Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Applications Overview Device Mounting Device Operation Device Power-Up Instructions Device Power-Down Instructions Mounting and Bonding Techniques for Millimeterwave GaAs MMICs Handling Guidelines for ESD Protection of GaAs MMICs Handling Precautions Opening the Protective Packaging Storage Cleanliness Static Sensitivity Transients General Handling Mounting Techniques Eutectic Die Attach Epoxy Die Attach Wire Bonding Outline Dimensions Ordering Guide
