Datasheet HMC-ALH482 (Analog Devices) - 3
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 22 GHz
Pages / Page6 / 3 — HMC-ALH482. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 22 GHz. Absolute …
File Format / SizePDF / 287 Kb
HMC-ALH482. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 2 - 22 GHz. Absolute Maximum Ratings. Outline Drawing. Die Packaging Information
HMC-ALH482 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 2 - 22 GHz Absolute Maximum Ratings Outline Drawing Die Packaging Information
HMC-ALH482
v04.1009
1
Drain Bias Voltage +5 Vdc IP Drain Bias Current 60 mA ELECTROSTATIC SENSITIVE DEVICE H RF Input Power 5 dBm OBSERVE HANDLING PRECAUTIONS C Gate Bias Voltage -1 to 0.3 Vdc - Channel Temperature 180 °C Continuous Pdiss (T = 85 °C) 0.45 W RS derate 4.7 mW/ °C above 85 °C IE Thermal Resistance 213.3 °C/W (channel to die bottom) IF Storage Temperature -65 to +150 °C L Operating Temperature -55 to +85 °C P M A
Outline Drawing
E IS O N W O L NOTES:
[1] 1. ALL DIMENSIONS ARE IN INCHES [MM]. 2. TYPICAL BOND PAD IS .004” SQUARE. Standard Alternate 3. BACKSIDE METALLIZATION: GOLD. GP-2 (Gel Pack) [2] 4. BACKSIDE METAL IS GROUND. 5. BOND PAD METALLIZATION: GOLD. [1] Refer to the “Packaging Information” section for die 6. CONNECTION NOT REQUIRED FOR UNLABELED BOND PADS. packaging dimensions. 7. OVERALL DIE SIZE ±.002” [2] For alternate packaging information contact Hittite Microwave Corporation. Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 206
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
