Datasheet HMC-ALH445 (Analog Devices) - 2
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 18 - 40 GHz
Pages / Page6 / 2 — HMC-ALH445. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 18 - 40 GHz. Gain vs. …
File Format / SizePDF / 337 Kb
HMC-ALH445. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 18 - 40 GHz. Gain vs. Temperature. Broadband Gain vs. Return Loss
HMC-ALH445 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 18 - 40 GHz Gain vs Temperature Broadband Gain vs Return Loss
HMC-ALH445
v03.0410
1
Gain vs. Temperature Broadband Gain vs. Return Loss
14 15 10 IP 12 5 H 0 S21 10 S11 S22 (dB) -5 -10 GAIN 8 E - C -15 RESPONSE (dB) +25C IS 6 -20 +85C - 55C -25 4 -30 18 20 22 24 26 28 30 32 34 36 38 40 10 15 20 25 30 35 40 45 50 FREQUENCY (GHz) FREQUENCY (GHz) W NO O
Input Return Loss vs. Frequency Output Return Loss vs. Frequency
S - L -10 -10 R IE -15 -15 IF L -20 -20 P +25C -25 -25 +85C M - 55C A RETURN LOSS (dB) RETURN LOSS (dB) +25C -30 +85C -30 - 55C -35 -35 18 20 22 24 26 28 30 32 34 36 38 40 18 20 22 24 26 28 30 32 34 36 38 40 FREQUENCY (GHz) FREQUENCY (GHz)
Reverse Isolation vs. Temperature Noise Figure vs. Frequency
-10 +25C +85C -15 - 55C -20 RETURN LOSS (dB) -25 -30 18 20 22 24 26 28 30 32 34 36 38 40 FREQUENCY (GHz) Note: Measured Performance Characteristics (Typical Performance at 25°C) Vd1 = 5V, Id1 = 45 mA Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
1 - 193
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
