Datasheet HMC-ALH311 (Analog Devices) - 3
DescriptionGaAs HEMT MMIC LOW NOISE DRIVER AMPLIFIER, 22.0 - 26.5 GHz
Pages / Page6 / 3 — HMC-ALH311. GaAs HEMT MMIC LOW NOISE. DRIVER AMPLIFIER, 22.0 - 26.5 GHz. …
File Format / SizePDF / 274 Kb
HMC-ALH311. GaAs HEMT MMIC LOW NOISE. DRIVER AMPLIFIER, 22.0 - 26.5 GHz. Absolute Maximum Ratings. Outline Drawing
HMC-ALH311 GaAs HEMT MMIC LOW NOISE DRIVER AMPLIFIER, 22.0 - 26.5 GHz Absolute Maximum Ratings Outline Drawing
HMC-ALH311
v02.0209
1
Drain Bias Voltage +5 Vdc IP Gate Bias Voltage -1 to +0.3 Vdc ELECTROSTATIC SENSITIVE DEVICE H RF Input Power -7 dBm OBSERVE HANDLING PRECAUTIONS C Channel Temperature 180 °C - Storage Temperature -65 to +150 °C Operating Temperature -55 to +85 °C RS IE IF L P
Outline Drawing
M A E IS O N W O L NOTES:
Die Packaging Information
[1] 1. ALL DIMENSIONS ARE IN INCHES [MM]. Standard Alternate 2. TYPICAL BOND PAD IS .004” SQUARE. 3. BACKSIDE METALLIZATION: GOLD. GP-5 (Gel Pack) [2] 4. BACKSIDE METAL IS GROUND. [1] Refer to the “Packaging Information” section for die 5. BOND PAD METALLIZATION: GOLD. packaging dimensions. 6. CONNECTION NOT REQUIRED FOR UNLABELED BOND PADS. [2] For alternate packaging information contact Hittite 7. OVERALL DIE SIZE ±.002” Microwave Corporation. Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 146
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
