Datasheet HMC564 (Analog Devices)
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 7 - 13.5 GHz
Pages / Page7 / 1 — HMC564. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 7 - 13.5 GHz. Typical …
File Format / SizePDF / 632 Kb
HMC564. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 7 - 13.5 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC564 Analog Devices
HMC564
v02.0618
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 7 - 13.5 GHz Typical Applications Features
The HMC564 is ideal for use as a LNA or driver ampli- Noise Figure: 1.8 dB IP fier for: Gain: 17 dB H • Point-to-Point Radios OIP3: 24 dBm C • Point-to-Multi-Point Radios Single Supply: +3V @ 51 mA - • Test Equipment and Sensors S 50 Ohm Matched Input/Output R • Military & Space Small Size: 1.96 x 0.98 x 0.10 mm IE LIF
P M The HMC564 is a high dynamic range GaAs PHEMT A MMIC Low Noise Amplifier (LNA) chip which operates E from 7 to 13.5 GHz. The HMC564 features extremely flat performance characteristics including 17 dB of IS small signal gain, 1.8 dB of noise figure and output O IP3 of 24 dBm across the operating band. This self- N biased LNA is ideal for hybrid and MCM assemblies W due to its compact size, consistent output power, single +3V supply operation, and DC blocked RF I/O’s. LO All data is measured with the chip in a 50 Ohm test fixture connected via two 0.025 mm (1 mil) diameter bondwires of minimal length 0.31 mm (12 mil).
Electrical Specifications, T = +25° C, Vdd 1, 2 = +3V A
Parameter Min. Typ. Max. Units Frequency Range 7 - 13.5 GHz Gain 14 17 dB Gain Variation Over Temperature 0.02 0.03 dB/ °C Noise Figure 1.8 2.2 dB Input Return Loss 15 dB Output Return Loss 16 dB Output Power for 1 dB Compression (P1dB) 9 12 dBm Saturated Output Power (Psat) 14.5 dBm Output Third Order Intercept (IP3) 24 dBm Supply Current (Idd)(Vdd = +3V) 51 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
