Datasheet HMC374SC70E (Analog Devices) - 4
DescriptionGaAs pHEMT LOW NOISE AMPLIFIER 0.3 - 3.0 GHz
Pages / Page6 / 4 — HMC374SC70E. GaAs pHEMT LOW NOISE AMPLIFIER. 0.3 - 3.0 GHz. Absolute …
File Format / SizePDF / 537 Kb
HMC374SC70E. GaAs pHEMT LOW NOISE AMPLIFIER. 0.3 - 3.0 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC374SC70E GaAs pHEMT LOW NOISE AMPLIFIER 0.3 - 3.0 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC374SC70E
v01.0814
GaAs pHEMT LOW NOISE AMPLIFIER 0.3 - 3.0 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +7.0 Vdc Vdd (V) idd (mA) rf input power (rfiN)(Vdd = +5.0 Vdc) 15 dBm 3 75 T Channel Temperature 150 °C 3.3 75 m Continuous pdiss (T = 85 °C) 3.6 75 0.32 W (derate 4.88 mW/°C above 85 °C) s Thermal resistance - 205 °C/W (channel to lead) s storage Temperature -65 to +150 °C eleCTrOsTATiC seNsiTiVe DeViCe r Operating Temperature -40 to +85 °C OBserVe HANDliNG preCAUTiONs ie esD sensitivity (HBm) Class 0 lif p
Outline Drawing
m A NOTes: 1. pACKAGe BODY mATeriAl: lOW sTress iNJeCTiON mOlDeD plAsTiC siliCA AND siliCON impreGNATeD. 2. leAD mATeriAl: COpper AllOY 3. leAD plATiNG: 100% mATTe TiN. 4. DimeNsiONs Are iN iNCHes [millimeTers] 5. CHArACTers TO Be HelVeTiCA meDiUm, .015 HiGH, WHiTe iNK Or lAser, lOCATeD ApprOXimATelY As sHOWN. 6. DimeNsiON DOes NOT iNClUDe mOlDflAsH Of 0.15mm per siDe. 7. DimeNsiON DOes NOT iNClUDe mOlDflAsH Of 0.25mm per siDe. 8. All GrOUND leADs mUsT Be sOlDereD TO pCB rf GrOUND.
Package Information
part Number package Body material lead finish msl rating package marking [3] HmC374sC70e roHs-compliant low stress injection molded plastic 100% matte sn msl1 [2] H374e XXXX [1] max peak reflow temperature of 235 °C [2] max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX InformatioFn ofur p rnis rhiec d eb, d y A e n l al iovg eDrey a vice n s id t s b o p eliev lea d c t e o o be rd acc eurrast: A e an n d a re llioag D ble. H eovi we c ve e r, sn, I o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No Prd hoe n r O e: 7 n- 81- li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
