Datasheet HMC490 (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 17 GHz
Pages / Page8 / 3 — HMC490. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 17 GHz. P1dB …
File Format / SizePDF / 411 Kb
HMC490. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 17 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC490 GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 17 GHz P1dB vs Temperature Psat vs Temperature
HMC490
v03.0213
GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 17 GHz P1dB vs. Temperature Psat vs. Temperature
32 32 IP 28 28 H 24 24 20 20 C (dBm) 16 (dBm) 16 - P1dB 12 Psat 12 R 8 8 IE 4 4 0 0 LIF 10 11 12 13 14 15 16 17 18 10 11 12 13 14 15 16 17 18 P FREQUENCY (GHz) FREQUENCY (GHz) M +25 C +85 C -55 C +25 C +85 C -55 C A E
Gain & Noise Figure vs.
IS
Supply Voltage@ 14 GHz, Idd= 200 mA Power Compression @ 14 GHz
O 30 5 35 N 30 (%) 28 4 NOISE PAE 25 W 26 3 (dB), FIGURE 20 (dB) LO GAIN 15 24 2 GAIN (dB) 10 (dBm), 22 1 Pout 5 20 0 0 3 3.5 4 4.5 5 5.5 -10 -8 -6 -4 -2 0 2 4 6 Vdd (V) INPUT POWER (dBm) Gain Noise Figure Pout Gain PAE
Gain, Noise Figure & Output IP3 vs. Supply Current @ 14 GHz, Vdd= 5V* Power Dissipation
34 5 2 1.8 30 4 ) (W) N 1.6 O (dBm IS 1.4 26 3 E IP3 F IG 1.2 U 22 2 R DISSIPATION (dB), E 1 (dB GAIN ) 0.8 18 1 POWER 0.6 14 0 0.4 100 125 150 175 200 -10 -8 -6 -4 -2 0 2 4 6 Idd (mA) INPUT POWER (dBm) Gain IP3 Noise Figure Max Pdis @ 85C 14 GHz 12 GHz 15 GHz 13 GHz 16 GHz * Idd is controlled by varying Vgg Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
