ADPA7006CHIPData SheetPIN CONFIGURATION AND FUNCTION DESCRIPTIONSVGGB VVVVDD1BDD2BDD3BDD4B234567VREFADPA7006RFIN18RFOUTTOP VIEW(Not to Scale)14131211109VDET -002 186 VVVVGGADD1ADD2ADD3AVDD4A 20 Figure 2. Pin Configuration Table 7. Pin Function Descriptions Pin No.MnemonicDescription 1 RFIN RF Signal Input. This pad is ac-coupled and matched to 50 Ω. 2, 14 VGGA, VGGB Amplifier Gate Control. 3, 4, 5, 6, 10, VDD1B, VDD2B, Drain Bias for the Amplifier. 11, 12, 13 VDD3B, VDD4B, VDD4A, VDD3A, VDD2A, VDD1A 7 VREF Reference Diode. Use this pad for temperature compensation of the VDET RF output power measurements. When used in combination with VDET, this voltage provides temperature compensation to the VDET RF output power measurements. 8 RFOUT RF Signal Output. This pad is ac-coupled and matched to 50 Ω. 9 VDET Detector Diode for Measuring the RF Output Power. Detection via this pad requires the application of a dc bias voltage through an external series resistor. When used in combination with VREF, the difference voltage, VREF − VDET, is a temperature compensated dc voltage proportional to the RF output power. Die Bottom GND The pads and die bottom must be connected to RF and dc ground. INTERFACE SCHEMATICSGND 3 V 00 GGA,V 86- GGB 01 007 2 186- 20 Figure 3. GND Interface Schematic Figure 7. VGGA, VGGB Interface Schematic 8 04 VREF 0 00 186- RFOUT 0186- 20 2 Figure 4. VREF Interface Schematic Figure 8. RFOUT Interface Schematic VDETVDD1A, VDD1B 005 TOV 20186- DD4A, VDD4B 9 00 6- 018 2 Figure 5. VDET Interface Schematic Figure 9. VDD1A, VDD1B to VDD4A, VDD4B Interface Schematic 6 00 RFIN 20186- Figure 6. RFIN Interface Schematic Rev. 0 | Page 6 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 28 GHz FREQUENCY RANGE 28 GHz TO 36 GHz FREQUENCY RANGE 36 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING THE ADPA7006CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR THE ADPA7006CHIP VGGx AMR (ABSOLUTE MAXIMUM RATING) REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE
