Datasheet ADPA7005CHIP (Analog Devices) - 2
DescriptionGaAs, pHEMT, MMIC,1 W Power Amplifier, 20 GHz to 44 GHz
Pages / Page23 / 2 — ADPA7005CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY …
File Format / SizePDF / 522 Kb
ADPA7005CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 2/2019—Revision 0: Initial Version
ADPA7005CHIP Data Sheet TABLE OF CONTENTS REVISION HISTORY 2/2019—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 3 link to page 4 link to page 4 link to page 4 link to page 6 link to page 6 link to page 13 link to page 14 link to page 15 link to page 15 link to page 15 link to page 17 link to page 17 link to page 17 link to page 17 link to page 19 link to page 19 link to page 19 link to page 21 link to page 22 link to page 23 link to page 23
Features .. 1 Applications Information .. 15 Applications ... 1 Mounting and Bonding Techniques for Millimeterwave GaAs Functional Block Diagram .. 1 MMICs ... 15 General Description ... 1 Biasing ADPA7005CHIP with the HMC980LP4E .. 17 Revision History ... 2 Application Circuit Setup .. 17 Specifications ... 3 Limiting VGATE for ADPA7005CHIP VGGx AMR (Absolute Maximum Rating) Requirement .. 17 20 GHz to 34 GHz Frequency Range ... 3 HMC980LP4E Bias Sequence .. 19 34 GHz to 44 GHz Frequency Range ... 3 Constant Drain Current Biasing vs. Constant Gate Voltage Absolute Maximum Ratings .. 4 Biasing .. 19 ESD Caution .. 4 Typical Application Circuit ... 21 Pin Configuration and Function Descriptions ... 5 Assembly Diagram ... 22 Interface Schematics... 6 Outline Dimensions ... 23 Typical Performance Characteristic ... 7 Ordering Guide .. 23 Constant IDD Operation ... 13 Theory of Operation .. 14
Rev. 0 | Page 2 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING ADPA7005CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR ADPA7005CHIP VGGx ABSOLUTE MAXIMUM RATING REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
