Datasheet HMC863ALC4 (Analog Devices)
DescriptionGaAs pHEMT MMIC 1/2 WATT POWER AMPLIFIER, 24 - 29.5 GHz
Pages / Page11 / 1 — HMC863ALC4. GaAs pHEMT MMIC 1/2 WATT. POWER AMPLIFIER, 24 - 29.5 GHz. …
File Format / SizePDF / 930 Kb
HMC863ALC4. GaAs pHEMT MMIC 1/2 WATT. POWER AMPLIFIER, 24 - 29.5 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC863ALC4 Analog Devices
HMC863ALC4
v02.0118
GaAs pHEMT MMIC 1/2 WATT POWER AMPLIFIER, 24 - 29.5 GHz Typical Applications Features
The HMC863ALC4 is ideal for: High P1dB Output Power: +27 dBm • Point-to-Point Radios High Psat Output Power: +28.5 dBm • Point-to-Multi-Point Radios High Gain: 24 dB • VSAT High Output IP3: +38.5 dBm 9 • Military & Space Supply Voltage: +5.5 V @ 350 mA No External Matching Required 24 Lead 4x4 mm SMT Package: 16 mm² T
Functional Diagram
M
General Description
The HMC863ALC4 is a three stage GaAs pHEMT R - S MMIC 1/2 Watt Power Amplifier which operates E between 24 and 29.5 GHz. The HMC863ALC4 pro- W vides 24 dB of gain, +28.5 dBm of saturated output O power and 22.5% PAE from a +5.5V supply. High output IP3 makes the HMC863ALC4 ideal for point-to- point and point-to-multi-point radio systems as well as VSAT applications. The RF I/Os are DC blocked and R & P matched to 50 Ohms for ease of integration into higher A level assemblies. The HMC863ALC4 can be operated E over a Vdd range of +4.0 to +6.0V. IN S - L R IE
Electrical Specifications, T = +25° C, Vdd = +5.5 V, Idd = 350 mA* A
Parameter Min. Typ. Max. Min Typ Max Units LIF P Frequency Range 24 - 29 29 - 29.5 GHz Gain 20.5 24 24 dB M A Gain Flatness 2 1.5 dB Gain Variation Over Temperature 0.03 0.03 dB/ °C Input Return Loss 8 17.5 dB Output Return Loss 13 15 dB Output Power for 1 dB Compression (P1dB) 24.5 27 27 dBm Saturated Output Power (Psat) 28.5 28.5 dBm Output Third Order Intercept (IP3) 38.5 37.5 dBm *Pout/Tone = + 14 dBm Noise Figure 4.5 6 5 dB Supply Current (Idd) 350 350 mA Supply Voltage (Vdd) 4 5.5 6 4 5.5 6 V * Adjust Vgg1 between -2 to 0 V to achieve IDD = 350 mA; Typical Vgg1 = -0.75 V. I F nf o or r p mati roic n e fu , d rnis e h leiv d e b ry y , a Analn o d t g D o p evic leac s i e o s bel rid ev e e rs d t : A o b n e a a lco c g D urat e e a v n ic d re elsi, I abl n e c . H , O owe n vee T r, n e o chn F o o lo r p g ri y W ce a , d y el, P ive.O ry . B , anox 9 d t 10 o pl 6 a , N c o e orrw de o r o s d, M : Anal A 0 o 2 g D 0 e 6 vi 2 c - e 9 s 10 , I 6 nc., responsibility is assumed by Analog Devices for it P s u h se on , no er f: 78 or an 1- y i 3 nfr2in9g-e4 m 7 e 0 nt 0 • O s of paterd nt e s or o r ot n h leir rights of third parties that may result from its use. Specifications subject to change without notice. No ne a O t w n w e Te w ch.a n n ol a o lgog. y Wcao y m , P.O. Box 9106, Norwood, MA 02062-9106
9 - 1
license is granted by implication or otherwise under an A y pa p te p n li t o ca r p t atio enn S t rig u ht pp s o o f A rnta: P lo h g D o e n vi e ce : 1 s. -80 P 0 ho -A ne NA : 7 L 81 O -3 G 2 - 9-D4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain & Return Loss Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Application Circuit
