Data SheetHMC637BPM5ESPECIFICATIONS FREQUENCY RANGE = DC TO 7.5 GHz TA = 25°C, VDD = 12 V, IDQ = 345 mA, VGG1 = GND, VGG2 = open, for nominal self biased operation, unless otherwise noted. Table 1. ParameterSymbol MinTypMaxUnitTest Conditions/Comments FREQUENCY RANGE DC 7.5 GHz GAIN 12.5 15.5 dB Gain Flatness ±0.5 dB Gain Variation over Temperature ±0.015 dB/°C NOISE FIGURE 3.5 dB RETURN LOSS Input 15 dB Output 15 dB OUTPUT Output Power for 1 dB Compression P1dB 25 28 dBm Saturated Output Power PSAT 30.5 dBm Output Third-Order Intercept IP3 39 dBm Measurement taken at output power (POUT)/ tone = 10 dBm SUPPLY Current IDQ 345 mA For the external bias condition, adjust the gate bias voltage (VGG1) between −2 V up to +0.5 V to achieve the desired quiescent current (IDQ) Voltage VDD 8 12 13 V Rev. A | Page 3 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS FREQUENCY RANGE = DC TO 7.5 GHz ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT EVALUATION PCB BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
