Datasheet HMC637A (Analog Devices) - 3
DescriptionGaAs MMIC 1 WATT POWER AMPLIFIER DC - 6 GHz
Pages / Page8 / 3 — HMC637A. GaAs MMIC 1 WATT. POWER AMPLIFIER DC - 6 GHz. P1dB vs. …
File Format / SizePDF / 377 Kb
HMC637A. GaAs MMIC 1 WATT. POWER AMPLIFIER DC - 6 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC637A GaAs MMIC 1 WATT POWER AMPLIFIER DC - 6 GHz P1dB vs Temperature Psat vs Temperature
HMC637A
v01.0715
GaAs MMIC 1 WATT POWER AMPLIFIER DC - 6 GHz P1dB vs. Temperature Psat vs. Temperature
34 34 IP 32 32 H 30 30 ) m m 28 28 (dB (dB at 1dB 26 s 26 P P R - C 24 24 E 22 22 W 20 20 O 0 2 4 6 8 0 2 4 6 8 FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -55 C +85 C +25 C -55 C R & P A
Gain, Power & Output IP3 vs.
E
Output IP3 vs. Temperature Supply Voltage @ 3 GHz, Fixed Vgg
60 ) IN 45 m B 55 d ( 3 40 50 ), IP m 35 ) B S - L 45 d m t ( a 30 s R (dB 40 3 IP ), P 35 25 m IE B d ( 30 B 20 d 1 25 LIF ), P 15 B d ( P 20 in 10 0 2 4 6 8 a G 11.5 12 12.5 M FREQUENCY (GHz) Vdd (V) A +25C +85C -55C Gain Psat P1dB IP3
Output IP3 vs. Output Tone Power
60 55 50 ) 45 m (dB 40 3 IP 35 30 25 20 0 2 4 6 8 FREQUENCY (GHz) 0 dBm 10 dBm 20 dBm Informat F io o n r p furn risihcee d , d by e An lialvoe g rDy a evic n e d t s is o p belie lva e c d t e o o b rd e a e cc rursa: A te a n n a d lo reli g D able. e H v o ic weveers, I no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
