Datasheet HMC7441 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 27.5 - 31 GHz
Pages / Page10 / 4 — HMC7441. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 27.5 - 31 GHz. Output …
File Format / SizePDF / 558 Kb
HMC7441. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 27.5 - 31 GHz. Output IP3 vs. Supply Voltage, Pout/Tone = +28 dBm
HMC7441 GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 27.5 - 31 GHz Output IP3 vs Supply Voltage, Pout/Tone = +28 dBm
HMC7441
v00.0913
GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 27.5 - 31 GHz Output IP3 vs. Supply Voltage, Pout/Tone = +28 dBm Output IM3 @ Vdd = +5.5V
46 50 45 42 40 IP ) 38 ) 35 H (dBm (dBc 30 3 IP3 34 IM 25 20 30 R - C 15 E 26 10 27 28 29 30 31 32 16 18 20 22 24 26 28 30 32 W FREQUENCY (GHz) Pout/TONE (dBm) O 28 GHz 30GHz 5.5V 6V 29 GHz 31 GHz R & P
Output IM3 @ Vdd = +6V Power Compression @ 27.5 GHz
A 50 40 1900 E 45 35 1775 ) IN (% 40 30 1650 AE ) 35 ), P 25 1525 Idd (dBc (dB 30 3 IN 20 1400 (mA) S - L A IM 25 ), G 15 1275 R m 20 10 1150 IE 15 out(dB P 5 1025 10 0 900 LIF 16 18 20 22 24 26 28 30 32 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 P Pout/TONE (dBm) INPUT POWER (dBm) M 28 GHz 30 GHz Pout Gain PAE 29 GHz 31 GHz A Idd
Power Compression @ 29 GHz Power Compression @ 31 GHz
40 2300 40 2300 35 2125 ) 35 2125 ) (% (% 30 1950 1950 AE 30 AE ), P 25 1775 ), P 25 1775 Idd Idd (dB (dB IN 20 1600 (mA) IN 20 1600 (mA) A A ), G 15 1425 ), G 15 1425 m m 10 1250 10 1250 out(dB out(dB P 5 1075 P 5 1075 0 900 0 900 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE Idd Idd Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
