Datasheet HMC7149 (Analog Devices) - 5
Description10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz
Pages / Page10 / 5 — HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. Output IM3 @ Vdd= …
File Format / SizePDF / 944 Kb
HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. Output IM3 @ Vdd= +32V. Power Compression @ 6 GHz
HMC7149 10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz Output IM3 @ Vdd= +32V Power Compression @ 6 GHz
HMC7149
v
IP 50 2250 50 H 45 2025 ) (% 40 1800 E 40 A 35 1575 , P ) 30 1350 Idd (mA) R - C (dB) (dBc IN 30 25 1125 E 3 A IM 20 900 ), G m W 15 675 20 10 450 O out(dB P 5 225 10 0 0 20 22 24 26 28 30 32 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 Pout/TONE (dBm) INPUT POWER (dBm) R & P Pout Gain PAE 6 GHz 12 GHz 18 GHz 8 GHz 14 GHz A 10 GHz 16 GHz Idd E IN
Power Compression @ 12 GHz Power Compression @ 18 GHz
50 2250 50 2250 45 2025 45 2025 S - L ) (% 40 1800 (% 40 1800 E E R A 35 1575 A 35 1575 ), P ), P 30 1350 Idd (mA) 30 1350 Idd (mA) IE (dB (dB IN 25 1125 IN 25 1125 A A 20 900 ), G 20 900 ), G LIF m m 15 675 15 675 P 10 450 out(dB 10 450 out(dB P P M 5 225 5 225 0 0 0 0 A 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE Idd Idd
Gain and Power vs. Gain and Power vs. Supply Voltage @ 12 GHz Supply Curent @ 12 GHz
45 45 40 40 35 35 (dBm), GAIN(dB) 30 30 25 25 20 20 P4dB (dBm), Psat (dBm), Gain(dB) P1dB (dBm), Psat 15 15 24 26 28 30 32 340 510 680 850 1020 1190 1360 Idd (mA) Vdd (V) P4dB(dBm) Psat(dBm) Gain(dB) P4dB(dBm) Psat(dBm) Gain(dB) FIo nf r p orm raiticoe n , d fur e nislihvee d rby a y A n n d t alog o p Devila ce cs e o is b rd eli e ev res d : A to n b a e lao ccg D urat e e v anic d eresli, I abl n e c . .H, 1 Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 owever, no For price, delivery, and to place orders: Analog Devices, In c., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
5
Phone: 781-329-4700 • Order On-line at www.analog.com rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
