Datasheet HMC7054 (Analog Devices) - 2
DescriptionKa-Band HPA
Pages / Page8 / 2 — HMC7054. Ka-Band HPa. Electrical Specifications
File Format / SizePDF / 283 Kb
HMC7054 Ka-Band HPa Electrical Specifications
HMC7054
v03.0216
Specification Parameter Min. Typ. Max. Units Notes s Frequency range (MIL) 30 31 GHz Military band PA Frequency range (COMM) 29 30 GHz Commercial band H Reference frequency 10 MHz Reference output power -7.5 5 dBm Input Power 5 dBm Small Signal gain 42 42 dB Gain flatness -1Ghz 3 dB Gain flatness -40Mhz 0.7 dB Gain variation (over temp) ±1.0 dB Gain stability ±0.25 dB/24h Group delay - 40MHz ±0.25 nSec Group delay - 10MHz ±0.1 nSec Input (VSWR) 2:1 RF output (VSWR) 1.5:1 With external Isolator Linear power 37 dBm PSK P1dB 38.5 dBm TX maximum power (Psat) 39.5 dBm 3 dB compression Output IP3 47.5 dBm Power added efficiency 8 % Signal related spurious -60 dBc Non-signal related spurs -40 dBm TX single sideband spurs -40 dBm AM/PM conversion 0 2 Deg/dB PA mute attenuation 40 dB PA mute settling time 50 150 µs VDD (HPA) 4.9 5.1 VDC -5V -5.1 -4.9 VDC I (-5V) 75 mA IDD (HPA) 14.3 A DC power Max (RF) 89 W DC power (HPA mute) 21 W HPA Temp sense 0 0.78 V VDD_HPA_SENSE/RTN 4.9 5.1 V For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
2
Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D Document Outline Features Functional Block Diagram Electrical Specifications Small Signal Gain Output P1dB & PAE Saturated Output Power Linear Power (SRG) IP3 Absolute Maximum Ratings Outline Drawing Table 1. Absolute Maximum Ratings Table 2. J1 HPA Connector Pin Out Table 3. J2 BUC Connector Pin Out
