Datasheet HMC6981LS6 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 15 - 20 GHz
Pages / Page10 / 4 — HMC6981LS6. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 15 - 20 GHz. Output …
File Format / SizePDF / 841 Kb
HMC6981LS6. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 15 - 20 GHz. Output IP3 vs. Temperature,. Output IP3 vs. Supply Current,
HMC6981LS6 GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 15 - 20 GHz Output IP3 vs Temperature, Output IP3 vs Supply Current,
HMC6981LS6
v03.1018
GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 15 - 20 GHz Output IP3 vs. Temperature, Output IP3 vs. Supply Current, Pout/tone = +20 dBm Pout/tone = +20 dBm
46 46 44 44 T 42 42 m ) 40 ) 40 m m s (dB 38 (dB 38 3 3 IP IP 36 36 r - +25 C +85 C e 34 -40 C 34 800 mA 1100 mA 900 mA 1200 mA w 32 32 1000 mA o 30 30 p 15 16 17 18 19 20 15 16 17 18 19 20 FREQUENCY (GHz) FREQUENCY (GHz) r &
Output IP3 vs. Supply Voltage,
A
Output IM3 @ Vdd = +5V Pout/tone = +20 dBm
e 46 70 44 lin 60 42 ) 40 50 s - (dBm 38 (dBc) r 3 IP3 IM 40 36 ie 5V 15 GHz 16 GHz 34 5.5V 17 GHz 6V 30 18 GHz 19 GHz 20 GHz lif 32 p 30 20 10 12 14 16 18 20 22 24 m 15 16 17 18 19 20 Pout/TONE (dBm) A FREQUENCY (GHz)
Output IM3 @ Vdd =+5.5V Output IM3 @ Vdd = +6V
70 80 70 15 GHz 16 GHz 60 17 GHz 18 GHz 19 GHz 60 20 GHz ) 50 (dBc (dBc) 50 3 3 IM 40 IM 15 GHz 40 16 GHz 17 GHz 30 18 GHz 19 GHz 30 20 GHz 20 20 10 12 14 16 18 20 22 24 10 12 14 16 18 20 22 24 Pout/TONE (dBm) Pout/TONE (dBm) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
