Datasheet HMC-APH462 (Analog Devices) - 2
DescriptionGaAs HEMT MMIC 1 WATT POWER AMPLIFIER, 15 - 27 GHz
Pages / Page6 / 2 — HMC-APH462. GaAs HEMT MMIC 1 WATT POWER. AMPLIFIER, 15 - 27 GHz. Fixtured …
File Format / SizePDF / 328 Kb
HMC-APH462. GaAs HEMT MMIC 1 WATT POWER. AMPLIFIER, 15 - 27 GHz. Fixtured Gain vs. Frequency. Fixtured Pout vs. Frequency
HMC-APH462 GaAs HEMT MMIC 1 WATT POWER AMPLIFIER, 15 - 27 GHz Fixtured Gain vs Frequency Fixtured Pout vs Frequency
HMC-APH462
v03.0209
GaAs HEMT MMIC 1 WATT POWER AMPLIFIER, 15 - 27 GHz Fixtured Gain vs. Frequency Fixtured Pout vs. Frequency
20 40 18 36 16 32 3 (dB) GAIN 14 28 POUT (dBm), IP3 (dB) IP3@18dBm/Tone IP 12 24 P3dB P1dB H 10 20 15 17 19 21 23 25 27 15 16 17 18 19 20 21 22 23 24 25 26 27 FREQUENCY (GHz) FREQUENCY (GHz) S - C R IE
Input Return Loss vs. Frequency Output Return Loss vs. Frequency
IF 0 0 L -5 -5 P -10 -10 M -15 -15 -20 -20 R A -25 -25 E -30 -30 RETURN LOSS (dB) RETURN LOSS (dB) W -35 -35 O -40 -40 -45 -45 15 17 19 21 23 25 27 15 16 17 18 19 20 21 22 23 24 25 26 27 FREQUENCY (GHz) FREQUENCY (GHz) R & P A E
Absolute Maximum Ratings
IN L Drain Bias Voltage +5.5 Vdc Gate Bias Voltage -1 to +0.3 Vdc ELECTROSTATIC SENSITIVE DEVICE Drain Bias Current (Idd1 + Idd4) 530 mA OBSERVE HANDLING PRECAUTIONS Drain Bias Current (Idd2 + Idd3) 1060 mA RF Input Power 18 dBm Thermal Resistance 20.5 °C/W (Channel to die bottom) Storage Temperature -65 to +150 °C Channel Temperature 180 °C Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
3 - 179
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
