HMC590LP5E v04.1219 GaAs pHEMT MMIC 1 WATTPOWER AMPLIFIER, 6.0 - 9.5 GHzPin Descriptions Pin Number Function Description Interface Schematic 1, 2, 6 - 19, 23, 24, 26, N/C Not connected. T 27, 29, 31 M These pins and package bottom must 3, 5, 20, 22 GND be connected to RF/DC ground. S - S This pad is AC coupled and 4 RFIN R matched to 50 Ohms. IE This pad is AC coupled and 21 RFOUT matched to 50 Ohms. LIF P Power Supply Voltage for the amplifier. External bypass M 25, 28, 30 Vdd 1-3 capacitors of 100 pF and 2.2 µF are required. R A E Gate control for amplifier. Adjust to achieve Idd of 820 mA. W Please follow “MMIC Amplifier Biasing Procedure” 32 Vgg O Application Note. External bypass capacitors of 100 pF and 2.2 µF are required. R & P A E LIN For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D 6 Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature P1dB vs. Current Psat vs. Current Output IP3 vs. Temperature 7V @ 520 mA, Pin/Tone = -15 dBm Power Compression @ 8 GHz, 7V @ 820 mA Output IM3, 7V @ 820 mA Gain & Power vs. Supply Current @ 8 GHz Gain & Power vs. Supply Voltage @ 8 GHz Reverse Isolation vs. Temperature, 7V @ 820 mA Power Dissipation Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials for Evaluation PCB 115927
