Datasheet HMC590 (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC 1 WATT POWER AMPLIFIER, 6 - 10 GHz
Pages / Page8 / 6 — HMC590. GaAs PHEMT MMIC 1 WATT. POWER AMPLIFIER, 6 - 10 GHz. Pad …
File Format / SizePDF / 407 Kb
HMC590. GaAs PHEMT MMIC 1 WATT. POWER AMPLIFIER, 6 - 10 GHz. Pad Descriptions. 3 - 75
HMC590 GaAs PHEMT MMIC 1 WATT POWER AMPLIFIER, 6 - 10 GHz Pad Descriptions 3 - 75
HMC590
v02.0109
Pad Number Function Description Interface Schematic This pad is AC coupled and 1 RFIN matched to 50 Ohms. 3 Gate control for amplifi er. Adjust to achieve Idd of 820 mA. Please follow “MMIC Amplifi er Biasing Procedure” 2 Vgg Application Note. External bypass capacitors of 100 pF and 0.1 μF are required. IP H Power Supply Voltage for the amplifi er. External bypass 3 - 5 Vdd 1-3 capacitors of 100 pF and 0.1 μF are required. S - C R This pad is AC coupled and 6 RFOUT matched to 50 Ohms. IE IF Die Bottom GND Die bottom must be connected to RF/DC ground. L P M R A E W O R & P A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
3 - 75
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
