Datasheet HMC457QS16G, 457QS16GE (Analog Devices) - 3
DescriptionInGaP HBT 1 WATT POWER AMPLIFIER, 1.7 - 2.2 GHz
Pages / Page10 / 3 — HMC457QS16G / 457QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 1.7 - 2.2 …
File Format / SizePDF / 531 Kb
HMC457QS16G / 457QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 1.7 - 2.2 GHz. Noise Figure vs
HMC457QS16G / 457QS16GE InGaP HBT 1 WATT POWER AMPLIFIER, 1.7 - 2.2 GHz Noise Figure vs
v03.0907
InGaP HBT 1 WATT POWER AMPLIFIER, 1.7 - 2.2 GHz Noise Figure vs. Output IP3 vs. Temperature @ 1900 MHz Temperature @ 1900 MHz
50 10 9 48 8 46 7 44 6 42 GURE (dB) 5 11 OIP3 (dBm) 4 40 SE FI +25 C +85 C 3 NOI 38 -40 C +25 C 2 +85 C -40 C 36 T 1 34 0 1.6 1.65 1.7 1.75 1.8 1.85 1.9 1.95 2 2.05 2.1 1.6 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Gain, Power & IP3 Gain, Power & IP3 vs. Supply Voltage @ 1900 MHz vs. Supply Current @ 1900 MHz*
50 50 45 45 40 40 PLIFIER 35 35 M 30 30 Psat (dBm), OIP3 (dBm) Psat (dBm), OIP3 (dBm) 25 25 20 20 Gain ER A Gain 15 P1dB 15 P1dB Psat Psat OIP3 W 10 OIP3 10 O 5 5 4.5 4.75 5 5.25 5.5 440 480 520 560 600 GAIN (dB), P1dB (dBm), GAIN (dB), P1dB (dBm), Vs (Vdc) Icq (mA) & P R
ACPR vs. Supply Voltage @ 1960 MHz
A
Power Compression @ 1900 MHz CDMA 2000, 9 Channels Forward
E 50 -30 45 LIN 5V 40 Pout (dBm) -40 CDMA2000 4.5V Gain (dB) Frequency: 1.96 GHz 35 PAE (%) Integration BW: 1.228 MHz -50 Forward Link, SR1, 9 Channels 30 25 -60 20 ACPR (dBc) 15 -70 5.5V 10 Pout (dBm), GAIN (dB), PAE (%) -80 5 Source ACPR 0 -90 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) * Icq is controlled by varying Vpd. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 242
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
