HMC452ST89 / 452ST89E v02.0710 InGaP HBT 1 WATT POWERAMPLIFIER, 0.4 - 2.2 GHzNoise FigureOutput IP3 vs. Temperature @ 400 MHzvs. Temperature @ 400 MHz 50 10 48 9 46 8 44 7 42 6 40 GURE (dB) 5 +25 C 9 38 OIP3 (dBm) +85 C 4 SE FI +25 C 36 -40 C 3 NOI +85 C 34 2 -40 C 32 1 T 30 0 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) R - SM Reverse IsolationGain, Power & IP3 E vs. Temperature @ 400 MHzvs. Supply Voltage @ 400 MHz W 0 50 O -5 45 +25 C 40 -10 +85 C -40 C 35 R & P -15 30 A Psat (dBm), OIP3 (dBm) E ISOLATION (dB) -20 25 IN 20 -25 15 Gain Psat P1dB OIP3 -30 10 0.35 0.37 0.39 0.41 0.43 0.45 S - L 4.5 4.75 5 5.25 5.5 FREQUENCY (GHz) GAIN (dB), P1dB (dBm), R Vs (Vdc) IE ACPR vs. Supply Voltage @ 400 MHz IF Power Compression @ 400 MHzW-CDMA, 64 DPCH L 55 -10 P 50 -15 M 45 -20 Pout W-CDMA Gain A 40 -25 PAE Frequency: 400 MHz -30 Integration BW: 3.84 MHz 35 64 DPCH -35 30 4.5V -40 5V 25 5.5V -45 20 ACPR (dBc) -50 15 -55 10 Pout (dBm), Gain (dB), PAE (%) -60 5 -65 Source ACPR 0 -70 0 2 4 6 8 10 12 14 16 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m 9 - 126 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
