Datasheet HMC464LP5E (Analog Devices) - 9
DescriptionGaAs PHEMT MMIC POWER AMPLIFIER, 2 - 20 GHz
Pages / Page9 / 9 — HMC464LP5E. GAAS PHEMT MMIC. POWER AMPLIFIER, 2 - 20 GHz. Evaluation PCB. …
HMC464LP5E. GAAS PHEMT MMIC. POWER AMPLIFIER, 2 - 20 GHz. Evaluation PCB. List of Materials for Evaluation PCB 108344 [1]
HMC464LP5E GAAS PHEMT MMIC POWER AMPLIFIER, 2 - 20 GHz Evaluation PCB List of Materials for Evaluation PCB 108344 [1]
HMC464LP5E
v04.0218
T M S S - R IE LIF P M R A E W O P R & A E LIN
The circuit board used in the final application Item Description should use RF circuit design techniques. Signal J1, J2 PCB Mount SMA Connector lines should have 50 Ohm impedance while the J3, J4 2 mm Molex Header package ground leads and package bottom should C1, C2 100 pF Capacitor, 0402 Pkg. be connected directly to the ground plane similar to C3, C4 1000 pF Capacitor, 0603 Pkg. that shown. A sufficient number of via holes should C5, C6 4.7 µF Capacitor, Tantalum be used to connect the top and bottom ground U1 HMC464LP5E planes. The evaluation board should be mounted PCB [2] 109762 Evaluation PCB to an appropriate heat sink. The evaluation circuit [1] Reference this number when ordering complete evaluation PCB board shown is available from Analog Devices [2] Circuit Board Material: Rogers 4350 upon request. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9
Application Support: Phone: 1-800-ANALOG-D
