Datasheet HMC414MS8G, 414MS8GE (Analog Devices)
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz
Pages / Page8 / 1 — HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 …
File Format / SizePDF / 383 Kb
HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC414MS8G, 414MS8GE Analog Devices
v04.0607
GaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz Typical Applications Features
This amplifi er is ideal for use as a power Gain: 20 dB amplifi er for 2.2 - 2.7 GHz applications: Saturated Power: +30 dBm • BLUETOOTH 32% PAE • MMDS Supply Voltage: +2.75V to +5V 11 Power Down Capability Low External Part Count T
- SM The HMC414MS8G & HMC414MS8GE are high effi- S ciency GaAs InGaP Heterojunction Bipolar Tran- R sistor (HBT) MMIC Power amplifi ers which operate between 2.2 and 2.8 GHz. The amplifi er is packaged IE in a low cost, surface mount 8 leaded package with IF L an exposed base for improved RF and thermal per- P formance. With a minimum of external components, the amplifi er provides 20 dB of gain, +30 dBm of satu- M rated power at 32% PAE from a +5V supply voltage. The amplifi er can also operate with a 3.6V supply. Vpd R A can be used for full power down or RF output power/ E current control. W O & P R A
Electrical Specifi cations, T = +25° C, As a Function of Vs, Vpd = 3.6V A
E Vs = 3.6V Vs = 5V Parameter IN Min. Typ. Max. Min. Typ. Max. Units L Frequency Range 2.2 - 2.8 2.2 - 2.8 GHz Gain 17 20 25 17 20 25 dB Gain Variation Over Temperature 0.03 0.04 0.03 0.04 dB/ °C Input Return Loss 8 8 dB Output Return Loss 9 9 dB Output Power for 1 dB Compression (P1dB) 21 25 23 27 dBm Saturated Output Power (Psat) 27 30 dBm Output Third Order Intercept (IP3) 30 35 35 39 dBm Noise Figure 6.5 7.0 dB Supply Current (Icq) Vpd = 0V / 3.6V 0.002 / 240 0.002 / 300 mA Control Current (Ipd) Vpd = 3.6V 7 7 mA Switching Speed tON, tOFF 45 45 ns Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 58
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
