Datasheet HMC981LP3E (Analog Devices) - 10
DescriptionACTIVE BIAS CONTROLLER
Pages / Page17 / 10 — HMC981LP3E. ACTIVE BIAS CONTROLLER. Evaluation PCB. List of Materials for …
File Format / SizePDF / 998 Kb
HMC981LP3E. ACTIVE BIAS CONTROLLER. Evaluation PCB. List of Materials for Evaluation PCB EVAL01-HMC981LP3E [1]. 13 - 10
HMC981LP3E ACTIVE BIAS CONTROLLER Evaluation PCB List of Materials for Evaluation PCB EVAL01-HMC981LP3E [1] 13 - 10
HMC981LP3E
v01.0411
13 T M S - S R
LLE Item Description O TP1-10 Test Point R Careful PCB layout is critical to achieve stable and C1 4.7 µF Capacitor, 1210 Pkg. T low noise operation. The negative voltage generator C2, C4, C8 10 nF Capacitor, 0402 Pkg. N charge pump stage requires particular attention. C5 1 µF Capacitor, 0603 Pkg. O C6 10 µF Capacitor, 0603 Pkg. C7 0.1 µF Capacitor, 0402 Pkg. S C D1 Dual Series Shottky Diode, BAT54SLT1 IA R1 10k Ohm Resistor, 0402 Pkg. B R2 4.02k Ohm Resistor, 0402 Pkg. R10 Trim Potentiometer U1 HMC981LP3E Active Bias Controller PCB [2] 600-00099-00-1 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: FR4 Information furnish F e o d r p by A rnic alo e g , d Devi ecleis vie s rby eli, a eve nd t d to b o p e a l cc a ur c at e o e an r d d releiars ble , p . Ho le we a vesr, e c no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 2 Elizabeth Drive, Chelmsford, MA 01824 Phon rights of third parties that may result from its use. Specifications subject to change without notice. No e: 9 Ph 7 o 8 n - e 2 : 750 81- - 3 3 2 3 9- 4 4 3 F 70 ax 0 • O : 9 rde 7 r o8 nl-i2 n 50 e at -33 ww 7 w. 3 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. analog.com
13 - 10
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptiptliec.actio o m n Support: Phone: 1-800-ANALOG-D
