Datasheet HMC981 (Analog Devices)
DescriptionACTIVE BIAS CONTROLLER
Pages / Page18 / 1 — HMC981. ACTIVE BIAS CONTROLLER. Typical Applications. Features. …
File Format / SizePDF / 886 Kb
HMC981. ACTIVE BIAS CONTROLLER. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC981 Analog Devices
HMC981
v00.0611
ACTIVE BIAS CONTROLLER Typical Applications Features
Automatic Gate voltage adjustment (No Calibration • Microwave Radio & VSAT IP required) H • Military & Space Supply Voltage: 4V to 12V • Test Instrumentation Digital Voltage: 3.3V to 5V • Fiber Optic Modulator Driver Biasing Controls both Enhancement and Depletion type S - C • CATV Laser Driver Biasing devices R • Cel ular Base Station Adjustable Drain Current up to 200mA • Wireless Infrastructure Equipment Sink/Source Gate Current Capability LLE Optional Internal negative voltage generation that O can be disabled to use external negative rail R T Fast Enable/Disable N Trigger-out Output for Daisy Chain Power-Up and O Power-Down Sequencing S C IA B
HMC981 is an active bias control er that automatical y adjusts the gate voltage of an external amplifier to achieve constant bias current. It can be used to bias any enhancement and depletion type amplifiers operating in Class-A regime with Drain voltages from 4V to 12V and drain currents up to 200mA, offering a complete biasing solution. HMC981 achieves excel ent bias stability over supply, temperature and process variations, and eliminates the required calibration procedures usual y employed to prevent RF performance degradation due to such variations. All data shown herein is taken with appropriate probes. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
