Datasheet HMC7447 (Analog Devices) - 3
DescriptionE-BAND DETECTOR 71 -86 GHz
Pages / Page8 / 3 — HMC7447. E-BAND DETECTOR. 71 - 86 GHz. Detector Voltage vs. Temperature,. …
File Format / SizePDF / 387 Kb
HMC7447. E-BAND DETECTOR. 71 - 86 GHz. Detector Voltage vs. Temperature,. Frequency = 81 GHz. Frequency = 83 GHz
HMC7447 E-BAND DETECTOR 71 - 86 GHz Detector Voltage vs Temperature, Frequency = 81 GHz Frequency = 83 GHz
HMC7447
v00.0913
E-BAND DETECTOR 71 - 86 GHz Detector Voltage vs. Temperature, Detector Voltage vs. Temperature, Frequency = 81 GHz Frequency = 83 GHz
10 10 IP 1 1 H ) t (V t (V e e d 0.1 d 0.1 f-V f-V re re V V R - C 0.01 0.01 O T C 0.001 0.001 -14 -11 -8 -5 -2 1 4 7 10 13 16 19 -14 -11 -8 -5 -2 1 4 7 10 13 16 19 E OUTPUT POWER (dBm) OUTPUT POWER (dBm) T +25 C +85 C -55 C +25 C +85 C -55 C E
Detector Voltage vs. Temperature, Detector Voltage vs. Frequency,
R D E
Frequency = 85 GHz Frequency = 71 - 75 GHz
10 10 W O 1 1 P ) t (V t (V e e d 0.1 d 0.1 f-V f-V re re V V 0.01 0.01 0.001 0.001 -14 -11 -8 -5 -2 1 4 7 10 13 16 19 -12 -9 -6 -3 0 3 6 9 12 15 18 21 24 OUTPUT POWER (dBm) OUTPUT POWER (dBm) +25 C +85 C -55 C 71 GHz 73 GHz 75 GHz
Detector Voltage vs. Frequency, Reference Node Voltage vs. Pout, Frequency = 81 - 85 GHz Frequency = 75 GHz
10 10 1 ) 1 ) t (V t (V e e d 0.1 d f-V f-V re re V V 0.1 0.01 0.001 0.01 -14 -11 -8 -5 -2 1 4 7 10 13 16 19 -12 -9 -6 -3 0 3 6 9 12 15 18 21 24 OUTPUT POWER (dBm) OUTPUT POWER (dBm) 81 GHz 83 GHz 85 GHz Vref (V) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
