Datasheet HMC1094 (Analog Devices) - 6
Description50 dB, Logarithmic Detector, 1 GHz to 23 GHz
Pages / Page14 / 6 — HMC1094. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND 1. …
File Format / SizePDF / 569 Kb
HMC1094. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND 1. 12 VTEMP. RFIN 2. 11 LOGOUT. TOP VIEW. GND 3. (Not to Scale). RSV
HMC1094 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS GND 1 12 VTEMP RFIN 2 11 LOGOUT TOP VIEW GND 3 (Not to Scale) RSV
HMC1094 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS CC CC CC CC V V V V 16 15 14 13 GND 1 12 VTEMP RFIN 2 HMC1094 11 LOGOUT TOP VIEW GND 3 10 (Not to Scale) RSV RSV 4 9 RSV 5 6 7 8 V ND ND NC RS G G NOTES 1. NO CONNECTION NECESSARY. THIS PIN MAY BE CONNECTED TO RF/DC GROUND WITHOUT AFFECTING PERFORMANCE.
017
2. EXPOSED PAD. CONNECT THE EXPOSED PAD TO A HIGH QUALITY RF/DC GROUND.
12810- Figure 2. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic Description
1 GND Ground. This pin must be connected to a high quality RF/dc ground. 2 RFIN RF Input. The dc voltage level of the RF input should be 0 V. If the RF input has a dc level different than 0 V, use a dc block capacitor. 3 GND Ground. This pin must be connected to a high quality RF/dc ground. 4 RSV Reserved. This pin is reserved for internal use; leave this pin floating. 5 RSV Reserved. This pin is reserved for internal use; leave this pin floating. 6 GND Ground. This pin must be connected to a high quality RF/dc ground. 7 GND Ground. This pin must be connected to a high quality RF/dc ground. 8 NC No Connect. No connection is necessary for this pin; this pin may be connected to RF/dc ground without affecting performance. 9 RSV Reserved. This pin is reserved for internal use; leave this pin floating. 10 RSV Reserved. This pin is reserved for internal use; leave this pin floating. 11 LOGOUT Log Out. The log out load should be at least 1 kΩ or higher. 12 VTEMP Temperature Sensor Output. This pin requires a minimum 10 kΩ resistance or higher. 13 VCC Bias Supply. Connect a supply voltage to this pin with appropriate filtering. 14 VCC Bias Supply. Connect a supply voltage to this pin with appropriate filtering. 15 VCC Bias Supply. Connect a supply voltage to this pin with appropriate filtering. 16 VCC Bias Supply. Connect a supply voltage to this pin with appropriate filtering. EP Exposed Pad. Connect the exposed pad to a high quality RF/dc ground. Rev. A | Page 6 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION AND EVALUATION PRINTED CIRCUIT BOARD (PCB) SCHEMATIC EVALUATION PCB BILL OF MATERIALS FOR EVALUATION PCB PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
