Datasheet HMC662LP3E (Analog Devices) - 2
Description54 dB Logarithmic Detector, 8 - 30 GHz
Pages / Page8 / 2 — HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Electrical …
File Format / SizePDF / 479 Kb
HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Electrical Specifications, (continued). LOGOUT Interface
HMC662LP3E 54 dB, LOGARITHMIC DETECTOR, 8 - 30 GHz Electrical Specifications, (continued) LOGOUT Interface
HMC662LP3E
v05.0914
Parameter Conditions Min. Typ. Max. Units
LOGOUT Interface
T Output Voltage Range 0.9 1.8 V Output Rise Time [1] / Fall Time [2] f = 10 GHz 5 / 10 ns M
Power Down (EN) Interface
S Voltage Range for Normal Mode 0.8 x Vcc Vcc V - Voltage Range for Powerdown Mode 0 0.1 x Vcc V
Power Supply (Vcc1, Vcc2)
RS Operating Voltage Range 3.15 3.3 3.45 V O Supply Current in Normal Mode 88 mA T Supply Current in Power Down Mode 3 mA C [1] 0 dBm Input Pulsed; measured from 10% to 90% [2] 0 dBm Input Pulsed; measured from 90% to 10% TE E
LOG OUT & Error LOG OUT & Error
D
vs. Input Power, Fin = 8 GHz vs. Input Power, Fin = 10 GHz
R 2 3 2 3 ERR +25C 2 ERR +25C ERR +85C 2 ERR +85C WE ERR -40C ERR -40C O 1.5 1 ERROR 1.5 1 ERROR (V) (V) P 0 OUT 0 OUT (dB) (dB) LOG 1 -1 LOG 1 -1 Ideal Ideal Log Out +25C -2 Log Out +25C -2 Log Out +85C Log Out +85C Log Out -40C Log Out -40C 0.5 -3 0.5 -3 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm)
LOG OUT & Error LOG OUT & Error vs. Input Power, Fin = 14 GHz vs. Input Power, Fin = 18 GHz
2 3 2 3 ERR +25C 2 ERR +25C ERR +85C 2 ERR +85C ERR -40C ERR -40C 1.5 1 ERROR 1.5 1 ERROR (V) (V) 0 OUT 0 OUT (dB) (dB) LOG 1 -1 LOG 1 -1 Ideal Ideal Log Out +25C -2 Log Out +25C -2 Log Out +85C Log Out +85C Log Out -40C Log Out -40C 0.5 -3 0.5 -3 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) Unless otherwise noted: Vcc1, Vcc2 = +3.3V, TA = +25 °C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
