Datasheet HMC948LP3E (Analog Devices) - 2
Description54 dB, LOGARITHMIC DETECTOR, 1 - 23 GHz
Pages / Page8 / 2 — HMC948LP3E. 54 dB, LOGARITHMIC. DETECTOR, 1 - 23 GHz. Electrical …
File Format / SizePDF / 664 Kb
HMC948LP3E. 54 dB, LOGARITHMIC. DETECTOR, 1 - 23 GHz. Electrical Specifications, (continued). LOGOUT Interface
HMC948LP3E 54 dB, LOGARITHMIC DETECTOR, 1 - 23 GHz Electrical Specifications, (continued) LOGOUT Interface
HMC948LP3E
v02.0913
Parameter Conditions Min. Typ. Max. Units
LOGOUT Interface
T Output Voltage Range 0.9 1.8 V Output Rise Time [1] / Fall Time [2] f = 10 GHz 5 / 7 ns M
Power Supply (Vcc)
S Operating Voltage Range 3.15 3.3 3.45 V - Supply Current in Normal Mode 91 mA [1] 0 dBm Input Pulsed; measured from 10% to 90% RS [2] 0 dBm Input Pulsed; measured from 90% to 10% O T C TE E
LOG OUT & Error LOG OUT & Error
D
vs. Input Power, Fin = 1 GHz vs. Input Power, Fin = 5 GHz
R 2 3 2 3 Ideal Ideal Log Out +25 C 2 Log Out +25 C 2 Log Out +85 C Log Out +85 C WE Log Out -40 C Log Out -40 C O 1.5 1 ERROR 1.5 1 ERROR (V) (V) P 0 OUT 0 OUT (dB) (dB) LOG 1 -1 LOG 1 -1 ERR +25 C -2 ERR +25 C ERR +85 C -2 ERR +85 C ERR -40 C ERR -40 C 0.5 -3 0.5 -3 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm)
LOG OUT & Error LOG OUT & Error vs. Input Power, Fin = 10 GHz vs. Input Power, Fin = 14 GHz
2 3 2 3 Ideal Ideal Log Out +25 C 2 Log Out +25 C 2 Log Out +85 C Log Out +85 C Log Out -40 C Log Out -40 C 1.5 1 ERROR 1.5 1 ERROR (V) (V) 0 OUT 0 OUT (dB) (dB) LOG 1 -1 LOG 1 -1 ERR +25 C -2 -2 ERR +85 C ERR +25 C ERR -40 C ERR +85 C ERR -40 C 0.5 -3 0.5 -3 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) Unless otherwise noted: Vcc = +3.3V, TA = +25 °C Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
